Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Mar 5, 2022 at 6:35 AM Post #3,016 of 12,406
2 feet? My phone has a USB Type-C 2.0. it is the POCO F2 Pro. I am looking for a (very) short cable. How do you keep it attached to your phone?
Mine is over three feet!
And No, I am not into strap-on's 🧐
Mojo or Hugo2 stays on table, I pick up the phone, change tracks, check my emails, post on Headfi . . . .
Mar 5, 2022 at 6:36 AM Post #3,017 of 12,406
maybe this?
Meenova Ultra Tough & Durable iOS 15 to MicroUSB OTG Pro Cable 15cm 0.5ft for iPhone​
Do a search on Amazon UK
Thanks, but I have an Android phone, the POCO F2 PRO.
Mar 5, 2022 at 7:47 AM Post #3,018 of 12,406
Okay, I see.
If anyone else has any solution on how to attach the Mojo 2 to the phone, please tell :) Or, how do you carry it?
The attachment issue is almost identical for both the Mojo OG and Mojo 2, except that the Mojo OG had narrow grooves to facilitate using rubber bands as a means of attachment.
You should search the Mojo OG thread, because there are many posts and images of the various cables/cases/bags and other DIY methods that owners experimented with. True some of the cables will be no longer on sale, but their current equivalents will be.
Mar 5, 2022 at 9:59 AM Post #3,019 of 12,406
I have 6" C to Micro cable for Mojo 1 from Moon Audio also. However, signal kind of broken off once I put them in front jean pocket. I have a feeling the Micro connection is not sturdy. That's why 2 ft cable , Mojo2 in front and Note9 in back pocket and no drop in connection so far....
Mar 5, 2022 at 11:31 AM Post #3,021 of 12,406
I think the question is how do you keep the Mojo attached to your phone 'when you carry them outside'.
Mar 5, 2022 at 2:15 PM Post #3,022 of 12,406
Mar 5, 2022 at 2:24 PM Post #3,023 of 12,406
Hey all,
I am having the most frustrating time with my Mojo 2, and I cannot seem to determine if it's a problem with the Mojo 2 or my various source devices.
  1. iPhone 13 Pro - I have the lightning camera connector. I have set streaming to Hi-Res Lossless. But I seem to only get 44.1 today. Yesterday, I was getting the right reading. 2 days ago, it wasn't even working at all (output coming out of the phone).
  2. Hiby R6 (original) - Bought a 3.5 mm SPDIF to SPDIF cable. No audio even though the R6 indicated COAX was on. Verified no audio with Schiit Bifrost, so maybe it's the cable? Went USB-C out to USB-C in. Now Mojo 2 indicates 192 kHz for ALL audio (even though I was playing a mix of different bit depth/rate).
  3. A&K Kann Cube - This seems to be the only device working as expected.
Does the Mojo 2 work reliably for y'all? Particularly with the USB-C port? They made a HUGE miss with keeping micro-usb, so I've been trying to only use USB-C.
Mar 5, 2022 at 2:24 PM Post #3,024 of 12,406
As I always have, even with my previous Fiio.
In my coat pocket, and phone in my top (shirt) pocket.
keeping them separate achieves:
- reduced bulk
- frees up the phone, so I could easily pick it up to operate it.
- keeps EMI at bay.
I was cheecky with my previous reply, but wasn't joking.
Mar 5, 2022 at 7:13 PM Post #3,025 of 12,406
I've had the Mojo 2 for almost two weeks and as much as I love the OG, which I'll keep,
the Mojo 2 is for me sheer magic. Listening to "Pet Sounds" of the same album with crossfeed
on green - transports me back in time to California in the mid-60's, amazing. With crossfeed on red,
the Beatle's self-titled white album blows me away with the virtuosity on display, wow....I had no idea
it was so well performed and recorded. "Tomorrow Never Knows" from Revolver is gold too,
it's like the M2 knows exactly how to best reproduce each track!
I've also found the eq settings valuable, used very sparingly in the bass region so far
(obviously the eq as well as crossfeed settings can vary according to the setup).
Some can complain about the various features - or the price - and the M2's not for everyone
but I am one totally satisfied audiophile....again, Rob W., if you're reading this....you are amazing!
Mar 5, 2022 at 11:51 PM Post #3,026 of 12,406
Yeah the Mojo 2s coherency and oneness with the music is truly special. I honestly thought the Mojo would win in this department but the Mojo 2 is incredible at putting all the pieces together in a musical way whilst still retaining incredible separation and speed. I’m very impressed.
Mar 6, 2022 at 11:15 AM Post #3,028 of 12,406
Is anyone finding the Mojo 2 needs to be warmed up (playing for an hour or so) before it sounds good; when I play it cold first time it sound on edge and harsh up top/digital.. if I leave it playing for a while warmed up it starts sounding better and less steely.
I also find I have to use a relatively high quality source otherwise straight out of a computer it sounds a bit too harsh for me.
ps - this is not eq related (and I have few other baseline sources that I use to compare)
Mar 6, 2022 at 11:40 AM Post #3,029 of 12,406
I had similar experience but only once when I opened from box, it had bit bright and narrow sound but after an hour or so it changed. I have Mojo2 for week and it sounds right from switch on and don't need warm up now. May just first time thing for few electronics inside.
Cheers.
Mar 6, 2022 at 11:54 AM Post #3,030 of 12,406
I have a Poly left over from my OG Mojo and that is how Mojo2 is fed
If I could get my Poly to stream through the hotspot on my iPhone, that would probably be enough of a reason to buy the Mojo 2. Not sure I am willing to go through that nose bleed exercise again, though. Has anyone ever gotten that to work?
