"there is an intermix formula !"Mr Watts cannot bend the laws of physics. I am sorry that’s just how the world works.
Refer to this Watts post: https://www.head-fi.org/threads/cho...ge-95-of-thread.885405/page-150#post-16805793I am sure Mr. Watts has thought of that, he is very thorough
He didn’t say what load he used to measure clipping and at what frequency. Lower frequency requires more power.Refer to this Watts post: https://www.head-fi.org/threads/cho...ge-95-of-thread.885405/page-150#post-16805793
or perhaps you didn't get it.He didn’t say what load he used to measure clipping and at what frequency. Lower frequency requires more power.
He also didn’t address the issue most recordings are compressed and normalized around 0db and any boost can clip the signal.
My two-cents on your post, and to all upgraders to Mojo 2.
I would suggest leave the EQ off for a week or two. That's unless you are outright wanting to recreate the Mojo (1) tonality of course. Or compensating for brighter headphones.
Anyway most press reviews of the Mojo 2 suggest it has better bass, and overall meatier sound than the Mojo.
I say this because I always found Chord upgrades to sound bright at first until I adjusted.
When I initally went from a Meridian Explorer to Chord Mojo it about ten to fourteen days. After that I heard and located the bass as full, the tonal balance right, and everything in place. (The Mojo was right and the Meridian Explorer was wrong. The ME was right in a cheaper way I suppose.)
Before that, I found the Mojo sounded hollow and metallic, or thin as you describe the Mojo 2. Although initally I did notice it had more detail. Then within a few days I noticed it was smoother because it was clearer. (As opposed to the Meridian Explorer sounding smoother because it had more bass and mid-bass bloom. In other words, artificial warmth.)
When I bought the Hugo 2, it took a whole month to fully adjust. Life also felt too short not to listen constantly to the Hugo 2, so that was cool. At first listening to the Hugo 2 was like splinters of mostly, yellow, orange, and red light, were being fired. The new level of detail was blinding and bright; hence why it took a whole month. In the end though, bass on the Hugo 2 easily outclassed the Mojo.
Same when I got TT2. It took about two weeks. As with every upgrade, I could hear the improvements intially but I could not process it all as a whole.
Then when I started driving speakers directly with TT2, meaning no amplifier, I needed at least a week to adjust. More like three weeks to fully settle with it.
As I say, initially each upgrade sounded thinner and brighter. After adjustment, the better DAC simply sounded better.
My last advice is, to hear your new DAC at its best as soon as possible, listen to some new music. Then you're not comparing the old and new DAC, on tracks that you know by heart.
That’s not how “upgrade” works my friend. When was the last time you gone to see your neighborhood orchestra and you said to yourself the sound is too real I can’t process all that realism?
As a general rule, if you are “upgrading” and that upgrade forces you to listen to one or another kind of music or makes you feel like you need to avoid certain kind of music or recording (I don’t mean one or two specific badly mastered recordings), you are doing it wrong.
I suppose people will report back when they start experimenting EQ with different cans and music. Clipping at the analog stage is very bad and can potentially damage your headphone.Since volume control comes afterwards, if you set the volume at -10db, then you have extra 10db overload headroom, same as setting a -10db preamp at software.
Bottom line, the digital section will not overload, but its higher output into the analog stage may cause it to reach its max output sooner.
The load is irrelevant as that is after the analog stage. At any rate portable devices clip when they run out of voltage supply .
I told you he was thorough !
he did think of that "intermix formula " just as Mr. Spock stated.
No one said you are lying. If something is a real upgrade you will know it instantly at first listen (this is not related to burn in) - humans have very sensitive hearing and we know when something sounds right or wrong instinctively.Some people claim they do not have an adjustment phase. However I don't understand why.
What I said is what I experienced so don't call me a liar, and friend. Many other people report the same as me.
It's also what Rob Watts refers to 'brain burn-in'.
If you want to dispute me any more please go ahead. I will not be replying.
(Going to a live e.g classical concert is different. Your hearing a presentation you never heard before. Hence why at the very end of my post which you ridiculed, I said listen to new music.)
I’ve seen that happening with a bad USB cable losing connection for a fraction of time with my iPhone.On my 2nd (replacement) Mojo 2 and got the same ear piercing white noise twice in the space of 10 minutes. I just tried my iPad Pro and got it again after 20 minutes or so. Seems my original unit wasn't defective and there's obviously something going on when Mojo 2 is connected to some Apple devices. I haven't tired my iPhone yet.
It's happened with Micro USB connection, and USB-C connection (with 2 different good quality cables). No cables were moving/touched when this has been happening either. I'll do some more testing thoughI’ve seen that happening with a bad USB cable losing connection for a fraction of time with my iPhone.
push any analog Hifi amplifier and it clips - you can't change the laws of physics!I suppose people will report back when they start experimenting EQ with different cans and music. Clipping at the analog stage is very bad and can potentially damage your headphone.
FWIW - I’m using it with my Ipad pro 11 inch without issues so farOn my 2nd (replacement) Mojo 2 and got the same ear piercing white noise twice in the space of 10 minutes. I just tried my iPad Pro and got it again after 20 minutes or so. Seems my original unit wasn't defective and there's obviously something going on when Mojo 2 is connected to some Apple devices. I haven't tired my iPhone yet.
