elvispreasley
Member of the Trade: Perun
Well... It's a little better with iGalvanic now![]()
The source and the soft, what you are using as your digital transport - making a HUGE difference. Much greater then any cables and galvanic isolation, what you're trying to use - to improve the SQ.
Just an example. About a week ago I visited local Audio shop and decide to listen Meze Empyrean there, from their reference setup (Yulong DA1 and some expensive Cayin tube amplifier). The source was Macbook Air with Tidal, connected to DAC by USB cable. Immediately after I started to listen whole setup, I got a feeling that something is wrong there, cause the sound quality was far-far away from impressive...I decide to check the DAC settings in Tidal and found that exclusive mode was switched off. After I switched it on - the difference came immediately! Night and day difference!
So 300$ galvanic isolation + 500$ RAAL silver cable - are good things for sure, but without good transport it's just like feeding the Bugatti from the golden bucket with petrol, which random guy brought you in exchange of hamburger.
p.s: Also, I'm suggesting you to switch USB cables in your connection (small one - from source to iGalvanic and RAAL - from iGalvanic to Mojo)
