Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Aug 28, 2017 at 12:13 PM Post #33,587 of 42,916
You're running Windows 10 on iPhone? :astonished:
i have no problems with Mojo on Win 10.
I have been reading some scare stories, about people not being able to get their Mojo working on Win 10. Even fairly recently in this thread.
It means that I can't move to Win 10 because I use Mojo for monitoring when I use Cubase. I think support for Win 7 will last after 2020, as support for XP lasted longer than expected. However it's other software that will drop its support for Win 7 also that is a worry. Win 7 is the min spec for any new software bought today.
I am probably worrying before time, but I am worrying no less.
By the way, congrats on your picture two pages back. Stunning set up. I use Mojo with Q Acoustics BT3, but I am looking for a change soon. I might not go active this time. The New Rega Brio integrated amp is a nice slim-line shape to fit on my desktop.
The foam you have your speakers on is perfect. I am looking for some identical. I many layers of bits of white foam for now.
Aug 28, 2017 at 1:04 PM Post #33,588 of 42,916
I had an issue with Tidal crashing the computer with Mojo, when Tidal was allowed exclusive control over sound. That problem was fixed by installing the new drivers for Mojo. Other than that, I haven't had any problems with Mojo working on Windows 10. I use Tidal and foobar2000 for listening to music.
Thanks. I'm very happy with the setup. :)
The foam pads I have are Genelec's own, made for the M-series speakers.
Aug 28, 2017 at 5:11 PM Post #33,589 of 42,916
can i also have it attached to a recharging usb cable to my laptop to recharge,
while i'm using it as a preamp/dac to my powered speakers?
You "can" charge it with a laptop. I used the Mojo as a DAC/preamp for speakers. (Both active and passive.) However, when I did simultaneous charging and playback via two of the USB outputs of my laptop, the Mojo would overheat and shut off after awhile, even when placed upright for better heat dissipation. The solution I found was to use a 5V 2A micro USB wall charger. It's best to charge it to full before turning it on and playing music. This way, it will trickle-charge instead of the heavier power draw that occurs when you let the battery deplete more. Some do recommend letting the battery deplete from time to time for the sake of its long-term life, but I just left it on the charger permanently. At that point I also used a Behringer UCA202 audio interface to output TOSLINK to the Mojo.
Aug 29, 2017 at 12:11 PM Post #33,591 of 42,916
thanks to all who replied to my query on using the mojo while recharging at the same time.
from Tom @ Chord:
I would actually recommend not having it on charge all the time, as this can potentially damage the battery, however, you can charge and play, but everynow and then just unplug the charger and use the battery for a little while.
Aug 30, 2017 at 9:28 AM Post #33,594 of 42,916
Quick question on chargers. I'm using a 1 amp and it works fine. I don't use this as a desktop or ever charge and play at the same time. Figure that extra work and heat can't be good for it over time and I always baby my stuff... I'm OCD. They say 2 amp is optimal - when I look at 2 amp chargers there are so many, and all different wattage ratings and iq charging, adaptive charging... do I need a 2 amp? And if so which wattage/kind should I buy. Over time would a 3 amp be harder on the unit? Apologies if this has been asked already, this thread is huge, didn't seen anything in the faq at the beginning. Thanks for any ideas.
Aug 30, 2017 at 9:38 AM Post #33,595 of 42,916
Hello, I've just joined this site.
I purchased a chord mojo 2 weeks ago and have been using it with my iPhone/MacBook Pro and My about 15 year old Grado SR325i. I'm no audiophile, but noticed a huge difference in SQ.
My question is that I think my mojo may have charging issues. I can leave it on charge for 12 hours using an iPhone plus in to the mains, but the charging light continues flashing past the 10 hour charge time. When I power it on, the light is coloured green rather than blue. Has anyone else experienced the same? Should I go back to the merchant to get it checked out?
Aug 30, 2017 at 9:44 AM Post #33,596 of 42,916
If the battery light is flashing, your charger isn't powerful enough. I had this problem too with phone chargers. Hooking Mojo up with my PC fixed the issue.
Aug 30, 2017 at 5:45 PM Post #33,599 of 42,916
Here's the 5V 2A micro USB wall charger I used: http://www.ebay.com/itm/351330392350
More info: https://chordelectronics.co.uk/supp...ct-battery-mojo-hugo-hugo-tt/usb-charger-buy/
Aug 31, 2017 at 11:24 AM Post #33,600 of 42,916
Thanks for the recommendation, that looks good and an awesome price. If the 1 amp I am using gives from what I can tell a full charge without any issues is it safer or less wear and tear on the battery to use it over a 2 amp? I've heard higher rated chargers and quick charges wear out batteries faster? Anyone have any thoughts on that? I know I'm being way over the top here and over analyzing but I really pamper my stuff and like it to last as long as possible. I still have my first shure e5 iem that I bought, it's 10+ years old and in mint condition!
  • Back
