NaiveSound
- Nov 8, 2015
What Is a decent Dap that has Tidal and sounds good even when not paired with mojo?
You need to let it do a full charge, leave your power cable plugged in permanently from there on. If you do it this way it will stay warm and should never go hot or overheat.
Try charging the Mojo fully before using it and then leave the charging cable connected while in use. As the battery will be fully, or near fully, charged there'll be less current draw into the charging circuitry and therefore less heat being generated.
I use my Mojo like this all the time and have had no cutouts, and the Mojo itself merely gets warm to the touch.
Use a power bank to charge, I've done that from the start with mine. Your Mojo will thank you for giving it a much cleaner 5v supply.
10.3.3 installed and still no Mojo love from apple. I'm using the original CCK and it does not work. Very bummed. Can anyone with the newer larger CCK confirm
that 10.3.3 works with it and Mojo?
Doesn't Bluetooth downsample? Not enough sample data SQ-wise.
SQ is being sacrificed in some way with Bluetooth and/or CCK? That's what I'm trying to avoid for next purchase.
Same here was told the 10.3.3 beta worked but the final release doesn't work for me either.10.3.3 installed and still no Mojo love from apple. I'm using the original CCK and it does not work. Very bummed. Can anyone with the newer larger CCK confirm
IMO, if you want the no compression whatsoever you can get the Poly with WiFi streaming or even a cheapo Chromecast Audio to do the same thing as the Poly. For me, DAC makes a much more effect in sound than a no compression streaming from WiFi. To me, Hugo 2 through Bluetooth is superior than MojoPoly through WiFi streaming.
it’s likely your cable then. do you have a spare?
