Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Jul 12, 2017 at 5:46 PM Post #32,986 of 42,916
Don't worry, I realise that you were not dissing Chord.
I think that i have read two or three posts, mentioning issues with the driver for the Windows 10 update.
Interestingly the issue gives the appearance that the root cause is not that the driver code does not work, but that the signature has not been registered.
Sorry, but I cannot remember anyone posting a solution.
I am suffering from this problem too.
Using HP Spectre 13 Windows 10 64-bit
If you find the solution, please share it. Thanks
Jul 12, 2017 at 8:29 PM Post #32,987 of 42,916
BTW, does anyone get periodic clicks with Mojo.
When mine is plugged into Windows laptop i get ever so slight ticks every now and then. Actually annoying.
Jul 12, 2017 at 10:32 PM Post #32,990 of 42,916
BL is not as good imo.
I actually like the BL a little better than the Mojo, lol. I have both. IMO, Mojo is more musical but BL is more detailed. Using with SE846 and IE800 IEMs
Jul 13, 2017 at 12:17 AM Post #32,992 of 42,916
There was a post recently on the Hugo 2 thread, where the problem was that installing the new driver, caused Windows to reset the default sound settings, to output through speakers and not the dac. The solution was to reset the sound output setting, to the dac.
Jul 13, 2017 at 3:54 AM Post #32,994 of 42,916
Its a smidgen brighter but not more detailed, Mojo has the better transients and timbre.
Imo idsd bl did make my hd 650 sound very clear and detailed without being harsh, never heard voices that clear before. And the sound stage width was great. Bass digged deep to.
Jul 13, 2017 at 6:36 AM Post #32,995 of 42,916
My problem is the famous warning triangle in the Device Management App advising Windows 10 is not able to check the digital signature of the driver and as a consequence, the Chord Audio is not shown in the list of available audio devices
Do you know how to fix this? Thanks
Jul 13, 2017 at 6:37 AM Post #32,996 of 42,916
Do you know if I need to install both drivers, the generic Windows 10 and the Creators one? If so, in which order? Really I don't know what Creators refers to
Jul 13, 2017 at 9:47 AM Post #32,997 of 42,916
The Generic Windows Driver does not contain an ASIO driver. The mojo creators update is the latest driver published by chord that is needled for the creators update to windows 10 1(703 branch). you get that from chord. The generic driver should auto install. you need to do a manual install of the other (Mojo creators update)
Jul 13, 2017 at 10:51 AM Post #32,998 of 42,916
I have it too, when using mojo with youtube or tidal. With foobar (and ASIO) it is dead silent.
Yes, same setting like yours. In tidal, youtube or any other system sounds. I think this is actually a rather serious flaw.
Jul 13, 2017 at 1:33 PM Post #32,999 of 42,916
The creators driver version doesnt work with Mojo.
  • Back
