Ha! Enjoy your floating Mojos, chaps. Here's a couple more of it back on its perch in my home setup:
![sA1DcPG.png](http://i.imgur.com/sA1DcPG.png)
![3Ob0i0a.png](http://i.imgur.com/3Ob0i0a.png)
Thanks for the link and the explanation, I'm probably just freaking out about nothing here. Only thing that's not true for me is what Mr. Watts is saying in that post about no change in hiss levels when turning the Mojo off and on, I can definitely hear that a little bit, but this might just be because of the very sensitive FLC8S. Maybe I just have exceptional hearing and should see this from the positive sideHere are the comments from Rob Watts https://www.head-fi.org/f/threads/chord-mojo-dac-amp-☆★►faq-in-3rd-post-◄★☆.784602/page-379#post-12099045
The only engineering compromise is that the iPhone and iPad have higher noise floors, which mean that the hiss is masked, but also they will not be as good as the Mojo at detecting the stop and start of notes.
He said "With sensible sensitivity IEM's (Noble, Ultimate ears, Dita) I can hear absolutely no added hiss from Mojo".Thanks for the link and the explanation, I'm probably just freaking out about nothing here. Only thing that's not true for me is what Mr. Watts is saying in that post about no change in hiss levels when turning the Mojo off and on, I can definitely hear that a little bit, but this might just be because of the very sensitive FLC8S. Maybe I just have exceptional hearing and should see this from the positive side![]()
I was just reading the Headphonics review and it said that the X5iii didn't work too well with Mojo via OTG. Have you got it connected some other way?I for one think the X5iii and Mojo are an awesome combo and work great together. The Mojo is one device I will keep forever, i absolutely love the sound it produces.
If you are running the latest updates of everything - then you are performing the role of beta tester that all the different software/hardware works together ok.eeek thats impressive very rare chd76864.sys (chord?) caused a blue screen*i know i know why am i using windows hehe running latest everything on intel/nvidia creative update system was playing a wasapi flac over jriver
/me hides under the bed
I couldn't hear any hiss with JH Angie connected to Mojo. Guess I'm insensitive to hissI'm not sure there's anything odd. Given the FLC8's impedance of 11 Ohms and sensitivity of 107dB SPL/mW I wouldn't be surprised if you hear a minor hiss. They are sensitive earphones.
I hear a very minor hiss with the JH Angie (17 Ohm, 117dB SPL/mW) and Noble K10 as well (around 30 Ohm - sensitivity unknown but it is high). Also consider that some people are more sensitive to hearing hiss than others.
Anyway, it will hardly be a problem when music plays even though there is a slight hiss.
I can`t find answer to my question in this thread. Sorry if it was discussed million times before.
I have Mojo in my office system so what will be the best choice for the longest battery life:
1. My Mojo always connected to charger when it plays music.
2. My Mojo gets full charge at night and plays without charger during working day.
What option will be the best? And Why?
Thanks!
Not sure why you're looking for transport for the hugo2 here in the mojo thread but if you're just after something with an optical output and great UI why not go with the Cowon PM2 or a used P1. I quite like their UI and they have optical out so you can use them as a transport.Looking for a DAP to pair with the HUGO2 as a transport only as the DAC is just HUGO2. Which DAP has the best, fastest user interface, touch screen, with 200GB SD cards and Wifi/ blue tooth to permit streaming with TIDAL either on Wifi direct or via iPhone. Ideally under $1000? Don't care about sound quality of built in DAC or amp since will use optical or USB out to HUGO2 to IEM or TOTL Headphones.
THANKS
Any amp suggestions for mojo ang hd800? Thinking about matrix mstage 3b with balanced out but jot sure with the pairing.
Thanks
