Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Mar 5, 2017 at 5:46 PM Post #30,826 of 42,916
hi deftone,
when you mention if it doesn't reclock referring to ifi why is that. surely reclocking aids the dac in every way?
also i use to use an intona with a modimultibit. it receives, reclocks and reproduces the signal by 100% and provides full galvanic isolation to usb high speed. when i tried it was outstanding. a lifelike addictive sound where the vocals became akin so real that someone was having a direct conversation with you. its doing something right so many praise it. its not instant night/day it takes time to understand its full potential. i was looking at options for my new hugo and intona comes top so far. it does not affect asynchrous usb operation of dac at all and is 100% transparent. i have no links to intona but im sure their website show very good measurements. optical negates control of dacs timing to computer.
Mar 5, 2017 at 7:22 PM Post #30,827 of 42,916
What about Hugo2. Have you heard it?
Not yet i shoud have one in a month or 2
  hi deftone,
Because the Mojo already has a very good low jitter master clock (what Rob Watts believes to be the best one for Mojo as it is higher quality than the external units / it took him 6 years to perfect and eliminate source jitter) and adding a separate one not only means you reclock twice but you also have the chance to add their own noise that they create to the system. Its the lower system noise floor / RF / EMI reduction that i believe to be the most important. The designer knows his dacs better than anyone so id go with that he thinks is best.
So i only use and iFi idefender 3.0 to remove ground loop noise from my PC and then from there a dual ferrite usb cable to Mojo. iFi is bringing out an iGalvanic but im not sure if this reclocks, they have too many of the same sort of product which can get confusing.
If you personally feel that the intona improves the sound then excellent enjoy it, im just trying to explain you dont need expensive reclockers for Mojo.
Mar 5, 2017 at 7:51 PM Post #30,828 of 42,916
Deftone, I think you are confusing the USB and Optical inputs when you mentioned the low jitter master clock, what you said above only applies to Optical. Rob took steps to reduce RF noise on the usb input but he could only do so much with Mojo since it was designed to be mobile and runs on battery. Mojo, just like practically every other dac in existance benefits from a clean sounding source. Don't get me wrong, I can listen and enjoy Mojo without the Intona, but once I add it in music just starts flowing and the sound goes from good to great
Mar 5, 2017 at 8:05 PM Post #30,829 of 42,916
i understand, its from memory so i could be wrong but im sure that i read a post from rob recommending not to use a usb reclocker for mojo as they a poor quality in comparison. (i think someone was asking about the Wyred4Sound usb recovery.)
i tried to find the quote but no luck
Mar 5, 2017 at 8:09 PM Post #30,830 of 42,916
Is there a reason using mojo with note 3+UAPP sounds much better (better soundstage, detail, etc) than using with my laptop+mojo driver+foobar?
Same tracks with the note 3 sound great and dont understand why...
Mar 5, 2017 at 8:11 PM Post #30,831 of 42,916
You might have a really noisy laptop, does it sound smoother and less bright from your phone?
Mar 5, 2017 at 8:14 PM Post #30,832 of 42,916
Rob recommended intona to me. usb plus intona is better than optical due to small benefits of usb asynchrous timing was explained. not my words.
Mar 5, 2017 at 8:15 PM Post #30,833 of 42,916
Yeah smoother, detail still there, more 3d, fuller (not the best at describing lol)
You'd think it would sound the same, I suppose the main difference is the mojo is using UAPPs driver opposed to mojos own windows driver on the laptop...
Mar 5, 2017 at 8:18 PM Post #30,834 of 42,916
He was talking about the W4S Remedy actually. It's a good reclocker but sadly it upsamples to 96khz which messes with the timing of the transients.
Even though Rob put years of effort into eliminating source jitter, cleaner sources still result in audible improvements. Here is a review on Head-fi of the Spidif ipurifier, the op used it with a Chord Hugo and said "Everything was brought into a sharper focus, the bass became deeper, the cymbals crisper and there was a general greater level of silk smoothness to the music. It had better shape and definition, and a bigger soundstage, which in turn meant better separation."
http://www.head-fi.org/products/ifi-spdif-ipurifier
The same thing could be said about Intona, it brings everything into focus and removes the haze that was otherwise there, that is why I recommend it to those interested.
Mar 5, 2017 at 8:25 PM Post #30,835 of 42,916
Rob talks a lot about noise getting in to the audio path, creating noise floor modulation, and spicing up the sound (like audio MSG - his words) and killing depth. That's the whole reason for people using USB cleaners in the path, to clean up noise in the audio path. What you report sounds like the battery powered phone is sending a cleaner signal with less noise. I'm sure it has nothing to do with the UAPP app if there is no EQ engaged and it's sending the signal bit-perfect.
Mar 5, 2017 at 8:36 PM Post #30,836 of 42,916
Being that the mojo doesn't falsely present details do to perfect timing how could you make the sound better?
It's not perfect timing. The more expensive Chord DACs have progressively better timing accuracy. (But still not perfect.) That's one of their main selling points, what with the tap filter reconstruction algorithm thingamajiggers.
Oh, you're getting it that early? I thought you said you would have to save up for a lot longer.
I happen to be getting a Schiit Wyrd in a trade, so hopefully it'll be a nice addition to my system.
Mar 5, 2017 at 8:41 PM Post #30,837 of 42,916
Makes sense
I really shouldnt be bothering listening to mojo via the laptop...
Mar 5, 2017 at 8:42 PM Post #30,838 of 42,916
I don't know what the exact reason is, it might be the reclocking, or it might be the cleaner power, but the W4s recovery with a linear power supply does amazing things for my Hugo and mojo, everything is taken up a few notches, resolution, transparency, depth, you name it. All of a sudden the instruments and voices come to life, having a solid physical presence, Super focused pinpoint imaging and an incredible sense of space and depth, width and height.
Mar 5, 2017 at 8:56 PM Post #30,840 of 42,916
  So do I not need a Mojo for use with my laptop and desktop computers?  Is it a waste?  My laptop is a little noisy.  I probably would not use a Mojo on the go with a dap most likely
Thank you
Riley
It will undoubtedly sound better than your stock sound card, my situation is between my note 3 and my laptop - as always, YMMV
