Agreed, from the cd transports I've listened to it represented the best sound quality of any transport under £1,500, evidently I've not listened to everything, but at this price point it's main competitor appears to be the Cambridge CXC.
I was able to demo the Audiolab and Cambridge transports and I felt the Audiolab was the better sounding unit, more resolution and separation, and I preferred the overall sound signature, but these things are subjective.
I have a Sony JB940 minidisc and a DTC 750 DAT left over from my small recording studio my band had. Both in perfect condition with loads of my band recordings on them
I found a peculiar issue with the Dave recently. I just got my Envy in yesterday. Got everything hooked up etc. I started noticing a constant high pitched sound on higher volume levels. Much to high in normal listening sessions but it was still there and annoying me.
At first I thought the issue was with the Envy as I never noticed this issue on the Ferrum stack. Upon further inquiry, I noticed when I put the Dave in standby. The sound went away. Later I diagnosed it to be the LCD screen. When using Display 4 and the screen goes off the high pitched whine stops. Seems like the LCD screen is producing noise which the highly sensitive Envy is picking up.
Maybe the Ferrum did not have enough headroom to accentuate the issue. Or this might have been a new issue. Anyone noticed this before? Maybe with other tube amps? Thanks.
I tried both the XLR and the RCA. Both produce the same noise. XLR less. I believe the cable is better constructed. Best Copper interconnect Arctic cables could muster.
I don't know how to earth the Dave. Will look into this. Thanks.
Put a wire to a screw on the back and listen and other side to earth on the inlet. My high tone was imidiatly gone. I use unshielded rca and since than had that high pitch tone. Earthing and it was gone
