You need to go into DAC mode by simultaneously pressing left and right buttons (see manual). Yes it's a bit obscure.Hi all, a quick question. When Dave is in digital pre mode connected to my amp the volume is still adjustable. I thought volume would be non adjustable, then? Should I just crank up Dave to max and adjust volume via my amp? My amp is a Riviera AIC 10. thanks for your advice.
This fixes the output at -3db. Leaving DAVE in preamp mode and setting the volume to -3db has the same affect, but you also have the option to adjust the output to better suit the external amp's input sensitivity.
EDIT: Best to try both DAVE and Riviera controlling the volume. One may sound better than the other. I find DAVE's volume control to be very transparent, but it's probably safer to use Riviera's to avoid switch-on thump kind of accidents.
