I'm using AES because that's the best output from my Grimm MU1 server.Hmm, you're one of those very rare people who's tried AES on DAVE.
Dave easily handles 192kHz at this input (double the conservative spec) and sounds great. But the quality of the AES cable greatly influences SQ, as it did when I used BNC or USB in the past. It would save me a lot of money if this wasn't so.
Yes, you get a bass boost of almost 2dB at CF=3, but the primary benefit should be a more realistic soundstage, which is more obvious with headphones with a wide soundstage, as in my HEKse. I do feel you lose a bit of transparency though with CF (as with any DSP) so that may explain the slight loss of airiness. Most choices have pros and cons and on this occasion I think the pros outweigh the cons. I find CF=2 gives a better balance for my tastes, apart from classical music where the correct soundstage seems to be more important.I just checked the Dave crossfeed and it is on setting 3. tried 0 and the bass impact is substantially less. seems airier up top with 0 though, but the relative lack of low end made me swap back to 3 quite fast.
