Christer
- Nov 23, 2015
Hmm...Very interesting post—I think you're on to something.
My Sonore/SGC setup allows me to run Roon, HQP & LMS on the sonicTransporter i9 optical server, and then quickly switch the opticalRendu between the Roon, HQP and Squeezelite endpoint apps. Much to my surprise there is a noticeable difference. After a few hours of critical listening, I came to agree with your ranking. To my ears there was greater clarity with the LMS (and no harshness), and the soundstage was noticeably wider.
Shocking that LMS still wins after all these years. In 2006 I made my first serious foray into digital audio with a Slimdevices Transporter feeding a Headroom Max Balanced amp. I still have that system boxed up in the garage. Makes me wonder what it would sound like fed by an opticalRendu->PhoenixUSB->M Scaler chain...
cheers,
muski
What are MPD and LMS?
The only two players except iTunes, which sucks sq wise, I am familair with are Pure Music and Audirvana which I use on my mbp.
Are the Innous or any other Streamers compatible with those two?
I still have ZERO, ZIP, NADA interest in any of the subscription based Tidal, Roon, alternatives.
I want to pay once only and be done with it!
I may have said so before, but I have auditioned Roon on a VERY expensive and good system with my reference material and I was not overly impressed.
Audirvana or Pure Music sounded more transparent to me.
As far as Innous Streamers are concerned I have only auditioned one of those and I can´t remember which model it was. So maybe I did not hear their best one. But again with one of my reference recordings ripped onto it, the cd layer of the SACD did not impress me much either.
Definitely harsher and not as realisitic as the DSD 64 SACD or DSD 64 native file via my mbp and Audirvana. The cd via that streamer sounded as a cd without mscaling,ie. not very good.
But this was a few years ago and I am a bit curious to hear why so many laud them so much now.
But ideally I would like to try optical via a Streamer since optical can sound so good via optical out to Mscaler from my cd players.
Most Streamers only do usb don´t they?
It also seems like a bit weird to pay roughly half the price of an Mscaler for the Innous Phoenix to improve usb,if optical avoids the problem usb creates anyway?
Cheers CC
