psikey
- Jul 15, 2008
The fun of being early adopters. Same kind of fun if you own a Fiio
Do all Polys have the different color and texture? I just love Mojo texture and have high hopes for the "seamingless" integration...
That picture just...broke my heart!
Thank you, I have the pre-QR code version of Mojo, I might be on the "not so lucky" side... I appreciate your help, there's more for me to consider now...
Yes, kinda more textured, I also like it more, it feels like nothing I've had/seen before, smth special indeed.Does your Mojo have a very textured finish to it? Mine does which feels really premium. I think it’s a bit of a shame if they moved to a much more typical smooth finish like the Poly
That makes it clear for me. Thx!I have a post-QR Mojo, and I'd say the colour match is about perfect
Really disappointed with the poly. Aside from the frequent drop outs using airPlay, there is a major issue when using a MicroSD card. I have 159 artists (around 800 albums) on a 400 GB card.
Each time I turn on the Mojo/Poly it takes 29 minutes to fully load the list of artists. They slowly appear in alphabetical order. you have to exit the artist folder then re-enter it and more slowly appear.
That's right... 29 minutes!!!!!! Each time it's switched on!!!!!! This is the same for all DLNA apps I've tried and clearly a poly issue.
The card is formatted as ExFat and all the tracks are all ALAC. these files work perfectly on all other players/DACs.
I have tried reformatting the card etc but still the same issue.
It's fine if I want to listen to an artist beginning with 'A', but if I want to listen to Wilco on the way to work I have to wait half an hour for it it appear.
Is anyone else experiencing this issue?
Is there a standalone DNLA app for Android Wear 2 watches? would be great if i could connect the watch to Polys Hotspot and control the mSD card playback from my wrist, without having to connect to my phone at all.
As many of you will know we use a hard black anodised finished for all our units unfortunately even if the process is controlled very tightly. The ultra fine power sand material used for bead blasting does vary just , but it’s enough. Also the way in which raw aluminium is sold means that it can have minor variations is it’s purity these days because much of it is made from recycled aluminium material. These changes can have a minor effect on how the anodising allows the aluminium to take up the black die within the process this means there can be colour variations. We could have used a paint finish but this was not considered to give the right long term finish that we wanted for Mojo or Poly. Thinking about it perhaps we should have changed the colour of Poly completely to silver or red or blue perhaps though I’m sure virtually all will be housed in our case or new leather sleeve.no, but not all Mojos have same color and texture. the Poly will likely match the newer Mojos and not the older ones.
