gto88
- Dec 11, 2014
bare with my lazzyness, would point me the post.Look back over my previous posts for extensive information on this
I found your first post when you get 2Go back in page 191...started reading...bare with my lazzyness, would point me the post.
With IPad, i use maximum MPD to create Playlists.I couldn’t have 2GO recognize playlist on so card.
there is demo with android m.a.l.p app to add playlist, but I only have iphone,iPad.
what Is the requirement of the playlist, such as location on sd card or format of playlist?
I use the same, and I can see those playlist, but after turn off/on 2GO, in go figure, it still saysWith IPad, i use maximum MPD to create Playlists.
Please cut and paste into a message here (or PM me) a few lines from a playlist that gofigure cannot see on your sd card. Also cut and paste the corresponding full path- and filenames of the tracks on your sd card. Also give the full path- and filename on the sd card of the playlist itself.I use the same, and I can see those playlist, but after turn off/on 2GO, in go figure, it still says
no playlist on SD card.
I will PM you when I have those data tonight.Please cut and paste into a message here (or PM me) a few lines from a playlist that gofigure cannot see on your sd card. Also cut and paste the corresponding full path- and filenames of the tracks on your sd card. Also give the full path-and filename on the sd card of the playlist itself.
I have experienced some .wav files failed to play, just noise.I received my 2go last week, and been using it with Roon, DLNA, and MPD. So far its a decent experience, but one of the issues I've run into is MPD isn't able to pickup all of the music on the sdcard. Its finding 1/3 of the music files, compared to DLNA which is picking up everything. I'm thinking its some character(s) in the filename or Metadata that could be causing this, but wanted to see if anyone else ran into this. I've used the following MPD clients on android:
M.A.L.P
MAFA
Soundirok
Has Chord ever commented on the pops/clicks using the 2Go? I get them frequently using it with Roon.
I've used a slew of different Micro SD cards - and never found one that didn't work fine. Currently, I have a pair of SanDisk 1TB cards in 2go.I would welcome any views on micro as card speed recommendation to use with Hugo Chord and 2Go.
My understanding, which may be incorrect, is that they felt the last firmware update 'fixed' the problems. I'm not sure they're looking for anything any longer. If you're experiencing VinylPopsAndClicks you should (a) make sure you've got the latest firmware and (b) let support at Chord know.Has Chord ever commented on the pops/clicks using the 2Go? I get them frequently using it with Roon.
Doody
Thanks. I am running 1.03. That is as far as updates are allowing my unit. Is anytime running a more current version?My understanding, which may be incorrect, is that they felt the last firmware update 'fixed' the problems. I'm not sure they're looking for anything any longer. If you're experiencing VinylPopsAndClicks you should (a) make sure you've got the latest firmware and (b) let support at Chord know.
Doody
