All you desktop users have envious music sources, especially Antipodes. I would have no idea where to begin down the rabbit hole if I committed to stationary listening. I know I would want a clear separation of duties tho. Roon core on a NAS or any random PC/OS as long it has enough PWR and don't have skips/clicks. Roon core seems like it's just a backend service, don't need to get fancy. I would focus mainly on the endpoint side of things with the requirements of battery && optical. I wouldn't want to run Roon core and endpoint on the same system if avoidable. IMO, these would be my preferences. That's what makes the 2Go attractive is that it is battery-powered and a Roon endpoint, unfortunately USB. But it's likely optimised USB (no data, no power, just audio and pure Chord propreitary audio) and there is no cable to act as a potential RFI antenna, just a direct USB connection inside the aircraft aluminium. If there is desktop charging like the H2, then it seems like it's a near optimal Roon endpoint solution.
No offense to anyone if opinion differs, but not all optical sources are the same. For most optical devices (PC gaming motherboards, Mac, Daps), optical is just a tack-on cheapest cost-savings component feature and not well-implemented. You going to get a flat sound (CCA included) which maybe close to USB. It's another story with a well-implemented optical solution with the right synergy of OS and a glass optical cable. Not all optical sources are created equal.
https://www.head-fi.org/threads/watts-up.800264/page-112#post-15443146
Maybe in the next gen of Chord DACs, USB will catch up but for now I will stick with a solid simple battery-power optical solution. This works as a Roon endpoint as well, but since I'm mobile-only have no way to experiment. I wouldn't mind the 2Go though as a close second for convenience, but I want to enjoy what I have at least for this year.
We are humans with subjective opinions, but RW is a cyborg. I'll take his statements for fact versus highly-experienced random audiophiles any day related with Chord DACs.
Again, synergy with optimal OS is important:
Also if you use remaster compressed sources, it's going to be difficult to tell differences. You need the good close to master sources for variances. Streaming apps manipulate the SQ as well so not reliable HQ source. Might as well run optical out of a Televison to run tests. It's not the best implemented optical decoder and the cheapest part of the Televison.
Yes agreed on batteries and optical! My struggle is to make it such that mains powered USB connected is the same as optical and battery - and I am indeed getting there.
