nullstring
- Oct 24, 2008
The D1001 and D1000 are essentially the same.. as far as I know.
The AD700 sounds at least as good as the D1001. I am breaking my AD700's in right now.. and the AD700 is definitely better than the D1001... how much better.. I am not sure yet.
I think I am gonna recommend you get the AD700. From the sounds of it, you'll find them very comfortable. They are bigger than the D1001 and I think they are even more comfortable.
However, If you are going for sound quality only... you'd probably be happy with the RX700 though.
I've used the RX700 briefly and I can say it's definitely worth the extra money (to me at least) for the better comfort.
Originally Posted by bladefd /img/forum/go_quote.gif I actually had the D1000, not D1001 (I dunno the difference between the two). Anyways, I thought these were very comfortable. If the ear pieces were just a little bit bigger, my ears would completely go inside them. Right now, either the top part or the bottom part of my ears gets pushed inwards by the headphone. It feels perfectly fine until I take them off my head. After that, I get extreme soreness for about 5 minutes after I remove them and then fine after that. Outside of that, I really have no complains. I never tried out any better headphones than these in the past so my opinion is kind of limited TBH. I really am willing to get something new this time though and I would not mind.. Right now I am thinking of getting the AD700. Sound-wise, how would the AD700 compare to the D1000? I know the A700 is closed (Which would be a plus for me) but AD700 supposedly sounds much better and is cheaper. At this point, I would rather save $30 and get the AD700. |
