Itsvjsingh
I Dont worry too much about isolation, do suggest me what ever comes in your mind according to my music selection.I like your music selections. I would think a good balanced sounding IEM would be ideal, but one with deep bass response. Air travel needs exceptional passive isolation or ANC. There are a ton of great options up to your price limit, but where you live might make some option impractical.
My #1 recommendation would be the FiiO FH3, but I don’t know how available it is where you live, and there have been some QC problems recently, so you should get it from a store that will take returns easily. Isolation is not exceptional, but is better than average, with foam tips and probably with multi-flange tips.
I really like the ISN D02, and it has very good isolation with foam tips, but it has boosted upper midrange frequencies, which might sound quite harsh with some of your music selections. I use a small piece of micropore tape to solve this issue on my pair.
The ThieAudio Legacy 3 is another great sounding IEM. Isolation is the best of these 3 IEMs, but it has been plagued by QC issues as well. I happened to get a really good copy.
The Etymotic ER2XR has a neutral sound, but with decent bass quantity, and very good sub bass extension. Isolation is easily one of the best, when using the stock triple-flange tips. The deep insertion is something to consider, but people often can get used to it. It doesn’t bother me at all, but some people hate sticking things deep in their ears.
IEMs with only BA drivers, that are not vented, usually have some of the best isolation, but if you haven’t heard BA bass, you really should, to see if it is acceptable to you.
Isolation is the main challenge that I have with coming up with good recommendations. Will see if I and others can add more options.
Can you please tell me something about this two "AK Billie Jean & BGVP DM6" do let me know which will you pick or which one is better.
Thankyou so much bro.
