FastAndClean
Previously known as presata
That's what they doThe nx7 stabbed my ears
, the laymen outside that don't do tiprolling or have extra cables on hand will think it's a lousy earphone and they will have lost a customer. (Another example is the ****'s horrendous stock red flange eartips).
Will test somemore and burn in!
just received my blon bl03...
I think should be able to get by with the largest eartip
but I have my JVC Spiral Dot..
Recommended! Thanks BGGAR!
Interesting. There is a slight problem with the Blons...and it's something someone else mentioned to me too...it's the air that's pushed with the bass. It doesn't feel quite perfect. A bit hollow perhaps? Don't know if anybody else has found this?
I wouldn't call it a 'bleed' as such...as it doesn't affect the mids I don't think, possibly because the layering and stage is so good.
That's what they do
The hypetrain has just arrived. Initial tests are the BLON BL-03 is excellent for $28 USD.
Nice harmanish sound signature, non fatiguing and great timbre and tonality. Nice midbass and open soundstage. I think it does everything quite well.
Only thing is isolation is slightly below average, I don't think it can be used well in noisy environments, but it will be a very good set to chill out at home with.
And eartips and cables should be changed ASAP! Get a longer nozzle eartip like spinfits and the sound is improved exponentially. It's a pity these CHIFI companies package crap tips +/- cables with their well tuned IEMs, the laymen outside that don't do tiprolling or have extra cables on hand will think it's a lousy earphone and they will have lost a customer. (Another example is the ****'s horrendous stock red flange eartips).
I just tested... my ears seems 15 years younger...
or it could be that my Fiio FH1 actually could not produce higher than 15KHz..
hopefully I could maintain it for longer years...
This was my 1st thought. This tuning in a kxxs shell would kill but as it is it's for the people who will put in work. Like a weird joke. Tons of crap fit nice and these .....we can't have nice things apparently
Glad you like. They are making me re-evaluate what "good" is, and my favorites list.
I have also ordered the Tiger Cable....
With the blon .. is there a need to look at Audiosense during 11.11 ?
BTW, I think I've deciphered the last word in ANNOTATION: It's not DREAMS but DRAMS. They should sound best with some scotch.
That's what they do
Dem NASA aliens changed your hearingMaybe because I only hear up to about 13.5KHz, the NX7 sounds good to me.
The bass is ever so slightly off. It's most noticeable with a double bass line. Slight peaks and troughs in level that don't quite match what you would expect a double bass to do and the timbre isn't quite consistent. I only really noticed it by back to back listening to the Blon and the Semkarch.
Me too. I've a third pair on the way. Just sayin'The bass issues (as we've noted) are slight and could be outliers. As I would expect variances, batch to batch, for a single dynamic driver setup. But for $30 USD, I'm happy to have the Blon BL-03s in my collection.
