sampson_smith
- Jun 2, 2009
Here's a simple question for all of you more-experienced DIY'ers: I am currently trying to change the LED of my Gilmore Lite dedicated power supply (DPS). The reasons at first were simply aesthetic; I wanted to match the LED of the GLite amp itself with darker blue LED, as they were not matching beforehand. Upon opening the DPS, it appeared that there was visible accumulation the solder on both sides of the board where each of the LED's end wires went through the holes in the board. I assumed that it was a simple matter of heating the solder, freeing the LED, and then reinserting the new one with an addition of solder. It appears that when and if I free the LED, there will be excess remaining solder that will block the insertion holes. The LED is currently still attached but due to my loosening of its contact by brief heating, the LED is 'permanently' off. I am cautious about adding too much heat because I do not want to damage the board, so it currently remains that way.
I have read into soldering much and thought that a solder wick (copper filament) would adequately remove excess solder, but it is clear that the contacts are so close together that it would be difficult to remove it without merging the two contacts. I have thought about simply shearing the old LED off of the board with wire cutters, and then placing the new one on top. I have not tried this, as I speculate that this is not an effective way to make contact (wire on top of solder vs. properly inserting the wires through the board).
I assume that the above is actually a simple matter, and I'll ascribe my reluctance to get the job done to being a nervous first-timer. Any advice on what I or somebody with better experience should do would be very much appreciated!
