certified low noise tube?
Aug 22, 2011 at 9:36 PM Thread Starter Post #1 of 7
darked59
i bought a tube amp (336se) and im kind of new with tube, i saw those tube : nos 6sn7gtb sylvania chrome top, it say certified low noise specimen what that mean?
and also they gave some ''number''   9.8ma/9.7ma and 2,600gm/2,600gm
could someone explain me what are those number?
for first tube it look good, might buy it.
Aug 23, 2011 at 12:12 AM Post #2 of 7
I believe the 9.8mA is the cathode measurement and the 2600 is transconductance.
I would take the measurements with a grain of salt though. Especially if your buying tubes from e-pay. You buy from there, you roll the dice.
Aug 23, 2011 at 12:21 AM Post #3 of 7
This is probably more than you would ever want to know about tubes. http://mysite.du.edu/~etuttle/electron/elect27.htm
Aug 23, 2011 at 4:34 AM Post #4 of 7
Low noise has a lot more to do with the amp than the tube.
If you truly want low noise with tubes, then you want chokes and a very well filtered power supply.
The finest tubes won't stand a chance against a crappy power supply.
I know everyone talks about NOS tubes, etc., but you need a lot of iron and good capacitors for a good power supply. You either have to buy a good amp or build your own. The tube doesn't matter nearly as much as the circuit does, and you will have to pay for a quality power supply, whether you order it or build it yourself.
Aug 23, 2011 at 10:23 AM Post #6 of 7
It could mean that the tube tester used has a noise test which the tube passed.
The only way to evaluate any tube properly is your amp.
Aug 23, 2011 at 2:37 PM Post #7 of 7
from what i saw it should be all right, so ill buy it, thx for the help
