Dash
- Aug 10, 2005
I don't want to invest in a rsa cable for Angie without a true balanced output.
good stuff.
good stuff.
It should get sorted out then when they have a chance to reply.
"My case is warped, or not cut straight. I did get this second hand from a Head-fier, but it is in otherwise perfect cosmetic and functional condition. Can you please replace the outer chassis? I have included pics to show what I mean."
His reply:
Fairs fair.
Its the general view that follow up customer service is for those who bought the product first hand.
Buying second hand is always a risk. And the support and warranties etc often aren't there for the buyer of used goods, if a company was liable for their products as they change hands infinitely it would cause difficulties.
I understand your frustration as this is a defect at a manufacturing level. Did the person who sold it to you mention it?
Hello Everyone,
I just had a quick question about the Mini-M8. I wish to use the Mini-M8 with my Android phone (Samsung Galaxy Note 5), and I was just wondering if the "Optical/Coax. In" on the front of the Mini-M8 is just a standard 3.5mm connector/rounded optical connector input? As in, could I just use a 3.5mm male to 3.5mm male cable from my Note 5 to the Mini-M8? If not, what are my options?
I was thinking of picking up one of these 3.5mm cables if so: http://www.ebay.com/itm/141849289328?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks!
- InsanityOne
No, that won't work. The only digital output from you phone will be via USB. You will need to get a USB On the Go (OTG) cable to connect to the Mini-M8.The Mini-M8 cannot accept analog inputs. Unfortunately, I haven't tried it myself, but there are some other threads here on Head-fi regarding using USB OTG from various Android phones to feed into external DACs.
