MilhouseV
- Jun 23, 2015
With an updated Windows driver, there is a new option to set bit depth via the control panel - I believe that's what does the trick for DSD playback.
Foobar2000 now plays native DSD via ASIO proxy, with Centrance ASIO driver forced to DoP (DSD over PCM) mode. Not the most elegant solution, but it works. It does result in some clicks at the start of the stream and when the stream is terminated.
The DAC in this device definitely sounds quite well for this price category. To me there is a tendency towards neutral-bright signature, somewhere south of Sabre, but north of BurrBrown/TI devices. The jury is still out on the amp capabilities.
Would be interesting to see official specs or measurements from the device when it is utilized in the recommended "line out" mode - e.g. into very high impedance load (levels, distortions, noise etc.). I don't believe it swings up to typical 2V at 0dB.
