Features
Pure A class operation with individual LEF circuit (headphone output)
wide-ranging headphone correspondence (impedance 32~2000 Ohms)
Simultaneously 2 headphones out enabled
Speaker output equipment (impedance 4 - 8 Ohms)
Specifications
Input Sensitivity (RCA): Headphone: 3.15V / Speaker: 1.3V
Input Sensitivity (XLR): Headphone: 2x1.58V / Speaker: 2x650mV
Frequency characteristic: 10Hz - 100KHz (±3dB)
Total harmonic wave distortion factor: 0.01% (-80dB)
Signal-noise ratio: Headphone: 95dB / Speaker: 90dB (1W)
Rated output: Headphone: 32 Omhs 0.38W/200 Omhs 0.135W / Speaker: 8omhs 8W
Load impedance: Headphone 32 - 2000 Omhs / Speaker 4 - 8 Omhs
Recommendation impedance: 200 - 600 Omhs
Input terminal: 1 system (balance x1 and imbalance x1)
Output terminal: Headphone output 2 system (6.3mm 3.5mm) x2 / Speaker output x1
Power source: 100V and 50/60Hz
External size: 217 (W) x 308 (D) x 59 (H) mm
Weight: 2.1kg (substance only)
According to this (waaaaaahhhhh!!!!????
) another best suited high impedance amp....Why is so dificult to make an amp suited for low impedance cans also!!!!And if it is why do they recommend then the 200-600 Omhs ones?
