dimazbaik
- Nov 23, 2011
Thank you @baskingshark, luckily mine heading a correct simple way. Just hope it arrives before end of December.
The Zex Pro is a nice try from KZ. A noble failure and a good attempt at creating a new sound signature. I think the hardware is the problem. Maybe better drivers is the key.I still on the buy side or not for this IEM
Read one atter another reviewers make me hesitate ( order or not)
And still waiting another one go home..
Still daily driving my ZEX Pro to burn-in or get used to it.Dare I ask? What tracks are you guys listening to that brings so much ire about cymbals on ZEX Pro? I don't hear any cymbal problems on rock and alt-rock.
Triangles in Mahler's Fourth are but a distant and subdued artifact and timbre from the strings section suffers from that 10kHz crater. There's a significant rolloff in high treble that isn't easily corrected.
I highly recommend buying a pair of studio phones to retrain your hearing. Flat, neutral, and Harman are all different things. I like a spicy W shape myself. I don't pretend that every earphone must be tuned as such to be considered "good". My strong opinion is that the reader shouldn't, either.
Figure out what you like with EQ on a pair of monitors that have good shape shifting abilities (nearly anything from Beyerdynamic, Shure, AKG, and Sony 7506) and then look for an IEM that fits that profile from the reviews. AKG 240s will educate you about how mids and treble actually sound on recordings and are under $70. K52 are great, too and even cheaper. Those cymbal crashes are likely zesty due to being boosted to compensate for lossy streaming platforms and online sharing, not anything to do with a highly resolving headphone.
Sound engineers often check a mix through Apple buds or Beats. Keep in mind that recordings are mixed to a rule of averages for equipment available in the time period they were recorded, and you've just hooked up an audible oscilloscope with even cheap IEM like KZ and CCA. Before blaming the headphone, consider your materia and cross reference to a monitor, otherwise you're probably just making bad guesses.
Fwiw
My case with KZs usually took more than few days to get used to the sound.
Trusting crin original sets (haven't tried the optional with bonus foam tips), the cymbals usually in the back unobtrusive. Maybe i'm a bit too conscious of it, but after daily driving Aria for two month it is different.
Then came the case was with spotify ver of this song.
Not exactly my favorite song but its originally from my favorite album of Dir En Grey. and yeah, Dir en Grey recording quality is not the best thing around
the song came after i tried to switch the cable and making mistake with changing into Y*nyoo 16 core that up the clarity/treble and pairing it with CP100 which brings the treble forward. Bad combo.
The cymbal ended overpowering other sounds and its odd tails/decay kinda making the bad impression.
For the most part, the migration from Aria to ZEX Pro kinda makes me aware of the near sibilant and somewhat harsher treble of the latter
Still daily driving zex pro with original equip, once in awhile still be surprised with sibilance and harsh treble in songs that usually smooth in Aria. so yeah.
I got CRA (and ZEX pro) now.
CRA are a great pair for ~$12, very nicely made, very respectable overall, but treble is a bit brittle, and hardly worth any hype, IMHO.
-DQ6 are still one level better to my ears, while ZAX & CA16 - two levels.
DQ6 are not my favourite pair, but I do appreciate and respect this tuning, especially for the price.I have noticed that with you and your DQ6 is either a very good pair or synergy with your devices. I know I liked the Emerald better than the DQ6 I had and a couple of people already said they like the CRA better than the DQ6.
Nothing wrong with that some don't like some things as much as others do. Some like them pretty well and others even more. Don't care about the drivers. Actually makes sense as the Emerald is too coherent for it's price so that it is just the dynamic is quite believable.DQ6 are not my favourite pair, but I do appreciate and respect this tuning, especially for the price.
Emerald are a BA fake, and thus a very good "lithmus paper" for me, as well as "hearing cables".
We can definitely agree about "hearing differently".Nothing wrong with that some don't like some things as much as others do. Some like them pretty well and others even more. Don't care about the drivers. Actually makes sense as the Emerald is too coherent for it's price so that it is just the dynamic is quite believable.
I found the DQ6 tuning good but a little too safe. 3 drivers and a bit smooth up top not that the third wasn't doing things for the imaging and presentation and other things outside the basic FR.
I already explained it here.Dare I ask? What tracks are you guys listening to that brings so much ire about cymbals on ZEX Pro? I don't hear any cymbal problems on rock and alt-rock.
I can unironically listen to them (and am actually having them in my ears right now), so for $12 I consider it a success. Will probably keep them and not flip them, which is something I could not say for the past two KZ releases.CRA are a great pair for ~$12, very nicely made, very respectable overall, but treble is a bit brittle, and hardly worth any hype, IMHO.
Big step up from BL03, huh? I can't wait to compare the two. Now, you have me very intrigued!CRA with SendaEarfit Short tips is definitely not bass light. Its mids is warm, airy and transparent with very good extention in highs, sound-stage is huge. CRA's sound is simply a big step-up from BL03 to me.
