So, I have been focusing lately more on cables and current draw rather than the sound, especially with iPhone where we have a current limitation. ClieOS kindly shared his measurements, and I confirmed that with all the IEMs and Headphones I tried connected to 4.4mm output, in High Gain, I get:
One thing to note, once you are idling, no playback, the current drops to 50mA so you are not draining your phone's battery as much. This is a very good design practice!
- DSD256: 220 mA
- DSD128: 190 mA
- DSD64: 170 mA
For the reference, the volume level under these conditions:
w/UM Mentor Multiverse: v26
w/Elysian Annihilator'23: v39
w/Meze Empyrean: v43
w/ATH-R70x (470ohm, 99dB sensitivity): v65
R70x are my most demanding headphones, and even with iPhone XS and RU7 in high gain and DSD256, I was able to listen to R70x at 65 without any stuttering; could even push the volume higher.
But, I was still trying to force it into a stuttering condition with iPhone, to hit the current draw limit. Was only able to do that with Empyrean in high gain at DSD256 while pushing the volume beyond listening level when I raised it to 63 and current draw hit 230mA. Again, just running the experiment because we use different demanding headphones. Under this condition, once I drop to DSD64, problem goes away since it draws less current.
Another solution where you don't have to compromise switching to a different DSD format is to switch to a different cable. Tried my new @ddHiFi MFi07S and even at high gain, with DSD256, and ear shattering volume with Empyrean, the problem went away once I switched to that cable. I just assume, thicker power wires, less resistance, smaller voltage drop, and just below the threshold of current draw limit which made iPhone happy. Btw, absolutely beautiful cable with high build quality.
So, just in case if someone runs into a problem with their iPhone while listening to RU7 in high gain and DSD256, and you are driving your demanding headphones at a high volume, switching to a different cable is one of the solutions if you don't want to drop it down to DSD64. In my case, ddhifi MFi07S usb-c to lightning OTG cable did the trick!
Thank you very much for trying out different cable and charging combinations for RU7, this is very helpful to our users. I just added this response to the FAQ of RU7.
Maybe we should adopt a different set of names for the All-to-DSD modes. DSD64 becomes Standard, DSD128 becomes Turbo, and DSD256 becomes Insane. With these names, users won't be surprised that the DSD256 is not operable in certain conditions.
Stay updated on Cayin at their sponsor profile on Head-Fi.
