I almost avoided the splitter discussion completely. I believe extra dongle/splitter in the music chain will downgrade the audio performance slighlty because it introduce smore conection points and questionable cable implementation (inside the splitter). In addition, I still couldn't believe this is the hottest topic in past 20 pages of RU6. Since I didn't test nor paying enough attention to the "hidden" DAC in side the splitter, I find the related discussion fancinating. The hpothesis are so comprehensive that I seriously suspect the $20 splitter has a Microprocessor or even ADC built-in to handle the digital audio signal.
On the other hand, battery care and charging are some of my major concerns in past few years: I have to when I need to repeat this topic many times in different DAP threads. I still convinced that if your mobile phone support wireless charging, get a Qi certified wireless charging power bank to charge your mobile phone "occasionally" is a better option that hunting for this "so-far-non-existed" USB splitter.
I noticed some users are concern that wireless charging will heat up the mobile during charging and shorten the battery life. I'll take a look at this topic and want to share my observations:
Will wireless charging heat up the mobile during charging?
Yes, it will. According to
a recent study by ACS (American Chemical Society) compared the 10W wireless charger against conventional USB charger and noticed that wireless charging wil increase the temperature by 3.5°C for roungly 1 hour per charging cycle.
Will wireless charging shorten the battery life?
Theoretically , yes, but we cannot quantity the implication at this stage. Afterall, we are talking about 1 hours of 3.5°C temperature change per charging cycle only.
On a related not not directly relevant subject, ACS noticed that the SoH (State of Health) of 18650 battery will drop slightly (capacity from 94.5% to 92.5%) after 6 month of storage in different temperature chamber. That is 2% capacity downgrade with 20°C different over 6 month of 7x24 control experiment. Maybe 1 hours of 3.5°C isn't really such a big deal.
Other than wireless charging, will there be other charging issue that can heat up the mobile during charging?
Yes, all fast charging will heat up the mobile more than regular 5V2A charging. Please be reminded that QC3.0 is 18W based, and PD Profile 3 is upto 36W. While I didn't measure the temperature change, I do notice 18W QC3.0 is as heated as 10W wireless, if not hotter. Since the QC3.0 didn't really shorten the charging time by 50% if we measuring a complete charging cycle like the ACS experiement mentioned above, the temperature implication of fast charging should draw similar, if not more concern than the heating issue of wireless charging.
Another charging related issue can be more alarming if we are worrying about the heat issue of wireless charging. Charging and using the mobile phone at the same time will heat up your mobile phone, again most likely more than 3.5°C IMHO. If we want to keep the battery from heating up, we should avoid charging and using at the same time. Stop from RU6 for 30-60 minutes when you need to top up your battery, that will keep your battery cool.
Last but not least, dongle DC will speed up the aging of your phone battery. For example, if you are using 5 charging cycle per week original, using dongle DAC regularly will probably increase that to 6-7 charging cycle per week. If the usage remain unchage for a long time, the 500 charging cycle limit will shorten from 100 weeks to 71.5-83.3 weeks. This observation is bad for Dongle DAC business, but since we are on this subject, we might as well look at the full picutre.
At the end of the day, I hope we can put aside the heating problem of wireless charging and seriously consider this option instead of the never ending splitter searching.
