wape hatson
Do let us know how you find the pairing.Glad to hear this. I've got both ER4SR and ER2SE and my RU6 should be delivered in a couple days.
Will doDo let us know how you find the pairing.
I found this on samsung make RU6 run at 192khz.
Toggle off will run at 48khz
I want 44khz mode but could not found
Did you have ru6 connected when trying?This doesn't work for my S23. The toggle is gray, it can't be enabled.
What Samsung do you have?
Mine Note20Ultra
Update: still haven't used the 4SR since I got the 2SE , but the 2SE with the Cayin RU6 sounds really good. The timbre has improved some, note decay is a little longer and they're a little more dynamic and enjoyable compared to the apple dongle. Sound is also more enveloping and less of a "2D soundstage ". Very happy so far. I've also been using it to drive my HD600s and they sound amazing. Bottlehead crack /speedball on the way however, to drive the senns. But the RU6 with the Etys is definitely my default portable pairing from now on.Do let us know how you find the pairing.
Found this matter on my Tab s9.Yes, I had it connected. Maybe this works on models that still have a 3.5 jack.
How did you clear the settings for USB devices on your iphone?I'm experiencing the kind of static and hissing at the end of and in between tracks that other users have reported, using an iPhone 15 Pro Max and the stock cable (I believe the unit is fine, because I don't hear this when it's plugged into a PC; airplane mode, wi-fi / cellular off, bluetooth disabled...none of it has any effect). I noticed that if I turn my iPhone volume down from 100%, the sound actually gets louder through the RU6 (volume control on the PC has no effect).
When I decrease the volume on the RU6 to compensate, the static and hissing disappears. This doesn't seem to be the recommended configuration (documentation says run source at 100%), but other than eliminating the static I can't hear any other audible differences, certainly nothing negative.
Has anyone else experienced this? How does turning down the iPhone as a source make the signal from the RU6 louder?
I haven't experimented to see where the cutoff is, but the noise is definitely audible when the RU6 is >60 on volume, below 40 I can't really hear it.
EDIT: I discovered that this "backwards" volume control was the result of me selecting "headphones" when first plugging in the RU6. After clearing the settings for USB devices, I selected "other device" when connecting, and now the volume control has no effect (as expected). The static I was experiencing in between and at the end of tracks is also gone. Hope this helps someone else in the future! I am now absolutely enamored with this dongle (except I fear for the longevity of the USB cable, so a third-party OTG cable is on the way).
You’d never guess…How did you clear the settings for USB devices on your iphone?
Just got this device today.
If I use the default Windows 10 UAC2 driver, all is ok. If I use the latest Cayin driver, the audio interrupts every 2-5 seconds. While the audio is interrupted, I can hear the same noise as when you change the volume and you go to the next stage.
I would like to be able to play DSD, and as far as I understand you can only do that with Cayin's driver.
Do any of you encountered this issue?
I had no issues with windows10 + RU6 with foobar asio exclusive access. Was able to play dsd files. And had no stutters with Neutron player as well. Moved on to mac now and it's a pain as the local music playback always goes through resampling and no way to bypass it.I still have this issue, even though I reinstalled Windows (assuming there was something wrong on my part).
