seanwee
- Jun 9, 2015
Bad guy good audio review? I disagree with his opinion on the N5ii but then again he just hated the UI so much he neglected going in depth about the sound, his loss then.Posted 2 months ago. It's the first hit when searching on "Cayin N5ii". The one disclaimer is the reviewer does come across as a FiiO fanboy based on his other reviews I've seen. Not meant as slight against him, just could add to some biasness.
The limited time I've spent with the dap so far has been marginally above "good". There's still that overall harshness which makes lengthy listening a tad tiring compared to a couple of my other DAPs. Perhaps I will try other IEMs although it will have to be SE out. Haven't tried the digital filter (only 2 options?) and I normally don't bother with EQ. The only real con I have at the moment is the screen, too small for big fingers.
The N5ii is definitely superb in terms of SOUND IMHO. It has more of a high end reference sound rather than a consumer oriented warmish tuning.
I will say that the N5ii will come across as brighter than most daps in its price range because most have a warmer tilt but harshness depends more on your gear, song and general preference imo.
