So after reading your post I decided to test again my Atriums and VCs using the 4.4 and xlr outputs. My Cayin is using Elrogs ER300Bs and Linlai Global Elites.You have a very good point. I am not 100% convinced the amp has a fault because based on other people's comments from this forum the ZMF VC is not totally silent with 300B and Zack has recommended using the 4.4 balance which I have tried and it is indeed almost silent (have to listen hard for the low buzz). In short, I can have an almost silent experience but I prefer the better dynamics of the XLR output hence trying o minimize the low buzz. I am also convinced my power line is dirty as connecting the amp directly to the power outlet increased the noise. Would love to hear from someone who has ZMF VC and plug their amp into the power outlet directly and did not hear any noise at all on the XLR output. So far, I have not seen confirmation. The amp has 2 years warranty so returning it is definitely on the cards
With the 4.4 I hear no hum, hiss or static with my Spring 3 KTE on mute for both the Atrium and VC. Off-mute, I also hear no hum or static. Once the volume gets around one and two oclock I can start to hear some background noise / hiss out of the VC and Atrium respectively.
With the xlr its a similar story for the Atriums. For the VCs however I immediately hear some low level hum and some intermittent static out of the right channel even with the Spring on mute. Off-mute is about the same until the volume gets to around 12 oclock then the background noise / hiss kicks in.
In my situation I'm pretty happy as I just use 4.4 most of the time and this works out well to my ears. However, it took some time to get the 4.4 perfectly silent at my listening volumes. After a few weeks of running the Cayin I started hearing some static out of the right channel on most days. I replaced the extension cord with the Power Plant 3 and still had that noise. Then replaced the stock tungsols with the Linlais and that did the trick - background was much darker and no more static.
