jonstatt
- Oct 5, 2012
Yes yes please work with Dignis to make this happen!
@Andykong You have a working relationship with Dignis already. Can you send them a C9 shell so they can make a case?
Any pointers? I couldn't find it at any of Cayin's official dealers.What store in the EU has the C9 in stock?
I asked at both Son Video in France and Hifi Sound in Germany. Didn't hear back any from them. Ended up ordering from AMP3 in UK who are very responsive.Any pointers? I couldn't find it at any of Cayin's official dealers.
I am surprised no one seems to care about a good IC with real Furutech or Pentaconn OFC lol
Furutech for sure, but Pentaconn has better reliability and denser tonal bodyBetween Furutech or Pentaconn OFC, which one provide wider soundstage?![]()
Small corner at home for a poor man just learning about music
Still learning after all these years?![]()
I am doing it through 3.5 to 3.5 mm IC, and I have tried both the Pre-in mode and line-in mode of C9. The effects are quite similar: You get mostly Hugo 2 sound signature plus a lot more power in the output. The sound did become slightly more analytical, I think partly due to me using the SS mode of C9.Good to hear about the Hugo 2 synergy. Any more impressions of this pairing? Are you going via RCA or 3.5mm to 3.5mm IC?
Isn’t the 3.5mm the phone out ? RCA will be your true line out. I think the differences of influences between sources that you observed is from the True line out on LPG vs the phone out ?I am doing it through 3.5 to 3.5 mm IC, and I have tried both the Pre-in mode and line-in mode of C9. The effects are quite similar: You get mostly Hugo 2 sound signature plus a lot more power in the output. The sound did become slightly more analytical, I think partly due to me using the SS mode of C9.
In addition, I have found that the degree C9 (even in line-in) changes the signature of the source vary from source to source. For example, I have always found Hugo 2 to have a dominant sound signature (in a good way), so what C9 does is mainly giving it more power. If I use a source like LPG, the change in sound signature is much more noticeable.
I have checked this. Hugo 2's line-out mode is really just setting its volume/output power to max. RCA and phone out all share the same source in the back, just different output formats as I understand it.Isn’t the 3.5mm the phone out ? RCA will be your true line out. I think the differences of influences between sources that you observed is from the True line out on LPG vs the phone out ?
So it doesn’t have any Line out, and that is why the C9 influences it differently than LPG which I assumes having true line outI have checked this. Hugo 2's line-out mode is really just setting its volume/output power to max. RCA and phone out all share the same source in the back, just different output formats as I understand it.
I think this is very true. From a different angle, this is not necessarily a bad thing for the combo of Hugo 2 + C9; I enjoyed its sound signature very much, but just have some complaint for its power in driving full-size headphones. Adding a C9 to it helps to address this.So it doesn’t have any Line out, and that is why the C9 influences it differently than LPG which I assumes having true line out
The C9 has the ability to expose the quality of line in performances from the source very well. That is how I come to realize the Max has a true Balanced Out Vs others which has Pseudo Line Out and especially VS just phones out
