atomicbob
- May 27, 2012
I have this theory that the Liquid Crimson club is pretty quiet, because the amp is so damned fine sounding that we all spend our free time listening instead of discussing. You picked one up over thanksgiving and have not posted back yet. I rest my case!
I have never bothered moving on from the stock tube, taking at their word those who have said that the Liquid Crimson doesn't really change all that much through tube rolling.
I got to the Crimson in a similar way - I bought and waited, and waited.... and waited for my Liquid Carbon, after having heard the Crimson at a meet. Sold the Carbon after getting the Crimson - it was just redundant after the Crimson arrived.
I have one minor niggle - I find the volume pot travel with my Ethers to be very limited. 7 to about 8:30 or so. I even bought (and sold) a pair of HD650's to see if the higher impedance would use more of the volume travel. No joy. I can't get to 9:00 on the volume knob. I have found a solution - a Schiit Sys passive preamp. I use it as an attenuation pad. Dac to Sys, set at 12:00 to 1:30 or so, to Liquid Crimson. I get good volume knob travel on the Crimson, and it appears to be sonically transparent. Some may scoff at blending an inexpensive volume pot into the mix that way, but it works nicely for me. The Sys volume pot is well into the linear region, so I see no real issues with this solution.
If the good doctor offered a reduction of the gain in the low gain setting, I'd probably be all over that. Mean time, the Sys is solving my only minor issue.
Well said, and on target.
I am privileged to have two very fine amps, Liquid Crimson and EC ZDSE. Much time spent listening to the library even though I have quite a backlog of items to measure / evaluate in the lab.
Nothing wrong with your passive attenuator solution. When presented with a similar mismatch I use a Goldpoint SA2 that I've had for years. The Sys is a very good option.
