Henmyr
- Aug 17, 2006
Hi. Yes, the star ground and the power strip ground should have the same potential, and measuring power strip ground - star ground gives a reading of 0.00mV, so it should be okey. I will be away for two weeks this time, but will try your suggestion when I get back. Thanks.
Originally Posted by Chaos4 /img/forum/go_quote.gif Henmry, All voltages should be measured with respect to star ground. If star ground and the ground you are using are the same potential all is good. I looks like you are measuring the op-amp correctly. I am going to suggest you try shorting across R15 (assuming you are working with the left channel) and see if you can get the voltages to stabilize to a single value. I don't think this should hurt anything, but you will want to be carefull, also this is just for test purposes. You will not want to leave the short there permanently. Unless AMB or someone else thinks this is a bad idea, it may at least settle the voltages down a bit so we can see what went wrong. |
