mandrake50
- Aug 13, 2007
I think you just answered my question. But to answer yours, Yes my Emotiva DAC one is now attached Both balanced and SE at the same time. If I remove the SE connection the SE input hums. This does compromise both the DAC and Amp in that SE inputs and outputs cannot be used with another piece of equipment.
I will give it a try, but I believe that simply adding a ground from the case or more likely back panel (chassis ground of some kind) of the amp and DAC would work as well. Saving the SE outputs and inputs.
