mandrake50
- Aug 13, 2007
Well, thank you for reviving my specious comments. Ok I exaggerated a bit. Yet, If I'm listening to Enya with the TH900's, I'm blissed out on one of her swirling waltzes, and then between the tracks is a noticible amplifier hum which is then covered up when the music starts up again. This is the only amp I have with noise on the SE. I will contact Cavalli. But tonight, thank you, I will take your suggestion and connect an RCA between my Emotiva and the LC. It is just connected balanced at the moment.
Let us know the results if you would. Creating a common chassis ground between the LC and DAC through the patch cable seems to have worked for several people that have posted here.
I stumbled upon the answer one night... by accident.
