Jaypee
- Nov 13, 2009
My caseworks have always been built from sheetmetal (nowadays I preffer aluminum sheetmetal)
Folding from sheetmetal usually makes things complicated, since most of the folding machines set geometrical restrainst to what you can do (ie. at least my workshops folders can't fold four walls, only three are possible). Also, if you're planning a chassis from folded sheet, depending on the material, the thickness is also a restraint for most folding machines.
With sheetmetal, connecting different chassis pieces together can also be difficult, if you're like me and don't like using corner brackets on all corners, and drill holes on every corner.
Check out my amp chassis design, if you're interested in working with sheetmetal.
..there's also a bit of aluminum welding on that case, Pabbi.
