rock-solid
- Mar 5, 2013
I don´t want to start a new discussion about sense or nonsense of burning in caps.
I would rather like to understand and hear opinions of the following circuit I found as my knowledge of reading circuits has become stunted due to lack of practice.
Main questions are:
- does this circuit give the caps some work to do in a similar way as in the headphone-amp?
- is there a risk for line-in-device or the battery?
- do the values for resistance and Watts for R1 reasonable? So if I want to put in 2 Caps rated at 400V I take 800 Ohm - 1.600 Ohm resistors with 7 Watts rating? And capacity of the capacitors is not relevant?
The Goal is to let the caps operate for about 400 hours without stressing the amp and the tubes.
Finding lots of opinions of long burn in time for certain caps there is little information of a device or rig for a separate burn in.
Would be happy if someone could shortly explain the circuit above and say whether it is ******** or ok in technical terms (I repeat: sense or nonsense of burn in should not be discussed here).
Thanks.
Main questions are:
Thanks.
