ph0rk
- Aug 28, 2003
For closed phones, I strongly recommend the Beyer DT-250-250's. Tough to beat - the 80-ohm models are an option too, but most devices that drive them drive the 250's acceptably.
Originally Posted by ph0rk /img/forum/go_quote.gif For closed phones, I strongly recommend the Beyer DT-250-250's. Tough to beat - the 80-ohm models are an option too, but most devices that drive them drive the 250's acceptably. |
Originally Posted by JayB18 /img/forum/go_quote.gif The Sennheisers (580, 600, 650) will require an amp so dont get thouse unless you plan to get a good dedicated amplifier in the near future, adding another couple hundred to your budget. |
Originally Posted by TopPop /img/forum/go_quote.gif I'm not sure why I keep reading this. I've tried the 600 straight from my Fuze and, although it doesn't sound as through a dedicated amplifier, it doesn't by any means sound bad. I still stand by my recommendation of the 600. It will provide a large immediate improvement, even straight from the laptop or E3, and will only get better later on down the road when the OP can afford a good dedicated amp. |
Originally Posted by JayB18 /img/forum/go_quote.gif Ive never listened to the 580, 600, or 650 but the general consensus is that they need an amp. I think that it would be a waist of money to purchase them when someone can get another pair of phones for less that will perform better than the Sennheisers do without an amp. |
Originally Posted by TopPop /img/forum/go_quote.gif I think, though, honestly, that a lot of the "general consensus" surrounding these headphones may actually be propagated through what people have read about them, but not actually experienced. A sort of audio "urban myth", if you will, which only grows larger with more posts that aren't necessarily based on experience. In my opinion, and (more importantly) my experience, the HD-600 perform acceptably without a dedicated amp. It would seem to be a better move in the long run to get a headphone which will improve noticeably with further upgrades, than get one that performs well enough now, but may not be as satisfying in the future with a better amp and source. Saves a lot of hassle and money that way... Just my $0.02. |
Originally Posted by lucky /img/forum/go_quote.gif Much of the general consensus on this forum is regurgitated groupthink. Listen to the phones yourself and determine whether or not you like them with your gear. In the end, the only opinion that matters is yours. |
