Regarding the elegia, it sounded a little congested to me. It was brand new and not broken in, so take that with a grain of salt.
Regarding the new zmf. New verete headphone. $2500ish. Clear, clean, tight, open but some isolation, warm, but not overly warm. Very nice. Listening through Zach’s “glen” OTL amp. Punch, in a good way. Complicated music doesn’t melt together. Maybe a little polite (amp). There are also two pad options, warm and warmer. Aeolus, also warm, but also very good.
Regarding the new Meze. Empyrean headphones. Crisp upper Mids and highs, Comfortable. Deep bass. Needs a good amp $3000. Leather pads more bass, maybe some bleed. Microfiber were cleaner, tighter. Includes a suitcase!
Regarding the Manley amp. Volume is very smooth. Neg feedback knob appears to increase the volume, but also the distortion (as expected). I really could not hear the distortion. Push pull vs SE, hard to tell difference. Overall, very nice. Complicated music wasn’t mushy. Bass well defined. Smooth “tube” sounds. Hard to listen for stage at the show.
Regarding the quad era-1. Meh, nothing to write home about
Regarding the Ether 2. Ether 2 through Brooklyn DAC+ and pass HPA-1 (at moon audio). Cable is nice, loosely sleeved quad cable, not microphonic. Great image. Clear, good bass, crisp mids. Bass is tight, but not th-900 level, still good sub bass. Some will still call these bright. I would use warm sources (tubes) with the Ether 2. At the schiit table through rag yiggy, fantastic. May be on par with the PMx2, but the PMx2 may have better mids. I still prefer the pmx2 Ether2 is excellent
Regarding ding the th-909. Open th-909. Very comfortable. Got that fostex bass! Not as shouty as the 900, but still a little v shaped. Show too loud
fostex has a contender here. Blue 900 is tuned a little differently from the red. Green and red are the same. 909 is not nearly as forward and shouty as the 900. But 900 sounds “cleaner” than the 909. Hard to identify differences, there are significant mid and treble differences between the 909 and 900. T60RP tuned a little bright. 610, still very nice, and easy to recommend.
