Thanks for the recommendations all.. My biggest issue is wet the seal and from what I've read, I'll try the Symbio first.
Campfire Audio Vega (and Dorado and Lyra II) - Head-Fi TV
- Thread starter jude
HeartOfSky
Ah. Wet seal is absolutely an issue I have, too. Here's what I do. It make look laborious, but it's worth it to get to use better-sounding tips.Thanks for the recommendations all.. My biggest issue is wet the seal and from what I've read, I'll try the Symbio first.
Jonathan Lerner
I have some bad problems with driver flex on the Vegas and although the included foam tips help they are really uncomfortable for me any recommendations?
- Jun 22, 2015
In the past I've always used a medium foam tip for IEMs. However I've found that for the Vega I need to use large foam tips to be comfortable. I've also found that going up a size didn't effect the sound.
So I use large CA foam tips for the Vega and medium CA foam tips for the Andromeda and Polaris.
HeartOfSky
Driver flex is a pronounced "feature" on the Vega. Not much to really be done about it. I assume you experience it only during insertion and repositioning, right?I have some bad problems with driver flex on the Vegas and although the included foam tips help they are really uncomfortable for me any recommendations?
Jonathan Lerner
Thanx for the advice but the included foams don't work they make my the inside of my ear hurt
Jonathan Lerner
Generally but it's really hard to get a good fit bc its actually quite when the air pressure is uneven
HeartOfSky
Which tips are you using?Generally but it's really hard to get a good fit bc its actually quite when the air pressure is uneven
I had this issue as well. The foamies caused pain/irritation in my ears that would take a few days to heal up. The stock black tips were nice, but the best sound for me was in the firmer silicone tips. But... I hated using them due to the hard seal, negative pressure, that they caused, resulting in no sound coming through. That's why I use a little bit of 1mm cotton cord to vent air through the bore. I swap out my tips ever few days, due to waxiness, so I swap out the venting cord then, as well. Venting my tips has been a total game changer.
HeartOfSky
You should definitely try to vent them. I bet it will make a world of difference for you in seating your IEM w/o having to worry about losing sound.Jvc spiral dots
I am not sure I understand. How would you vent the spiral dots?You should definitely try to vent them. I bet it will make a world of difference for you in seating your IEM w/o having to worry about losing sound.
HeartOfSky
Look up to post #4907. I've linked an image that shows what I mean.I am not sure I understand. How would you vent the spiral dots?
I think what he means is to give the earpiece or your own ear a little tug to break the seal, so the driver won't flex. A perfect seal is the root cause of driver flex in DD's.
