HeartOfSky
When one has tools more precise than a box cutter, they might as well make use of them.Just use a box cutting blade, you can poke the end of the wire through the plastic and pull down on it this will tear through the majorty of the heat shrink, finish the job carfully! with a box cutting blade, the memory wire will pull out of its foundation
Nice review graham to bad ure taste in music
