ashrafazlan
- Dec 26, 2010
I've heard a couple of the modded Series 5's, and it's apparent that obtaining a consistent result is quite tricky. Apparently the key is to puncture the filter just right, or even do a series of small pushes around the edges of the filter's circle so it dislodges. If done correctly, the sound is absolutely astounding. The one modded most successfully sounded noticeably better than the Andromeda to my ears, no doubt.
YES! This is the main problem with the S5, one that (to me) justifies Noble's and Campfire's pricing. Performing all 3 mods puts it in the range of K10's and Andromeda's but with all the benefits of DD drivers. However, that means diddly squat without a 100% success rate.
A bunch of us in Malaysia each ordered one and performed the mods. Only 3 out of 7 managed to do it right. I'm not sure if we punctured the vents wrong, or if the strips of alcohol swabs we cut were too thick or wide. I admit it can be pretty frustrating to end up with a dud. $75 might be cheap compared to TOTL iems, but is it worth the gamble for those with tight budgets? That's up for you to decide, but if you're lucky enough...boy, these things sing.
