Sep 20, 2012 at 8:03 PM Thread Starter Post #1 of 5
CodyD
The reason I ask is due to the MixAmp recently going OOS, I can however find them on Ebay less the cables. So, what cables would I need for the above setup?
And if anyone wants to chime in to the addition of the E11, please do. It seems the extra power may be needed for running the 990 PRO's along with the ModMic.
Thanks in advance!
EDIT: Found the MixAmp in stock, are there any additional cables that I would need for the above setup?
Nov 16, 2012 at 5:15 PM Post #3 of 5
Turns out nothing extra was needed, I have everything on hand except for the ModMic. The MixAmp has two cables that connect to the Xbox (usb and optical), then the headphones and mic plug right into the MixAmp. If you use a HDMI cable with your Xbox however, you'll have to grab an adapter due to the optical port being on the analog AV cable.
