BassDigger
The most likely explanation is either a) it is completely and solely your brain playing tricks on you, or b) the IC had a significant difference in resistance leading to a volume difference which is perceived by your brain as being different in not just volume, but things like "neutral" or "soundstage" etc.
If you really are an EE degree holder, you should know that a sighted listening test (ie "by feel") isn't proof that a difference exists. Measure it with oscilloscope and show it.
EDIT: I'm also an EE degree holder, and I specialized in analog and digital signal processing at that. But then again as I said this shouldn't matter a single bit, as the merit of the argument lies in the theories themselves, not the person presenting them.
I've been a cable 'believer' for decades, based on my own experiences, But now I'm trying to keep an open mind and understand why I've heard the differences that I have, between different cables, in different situations. I did, however, learn that brand name cables are typically a rip-off.
Anyway, I do believe in the adage that sound is more important than measurement; if it sounds good, but measures bad, you're measuring the wrong thing. I strongly believe in logic, cause and effect and that we should use our common sense, but it's also true that we (however clever) certainly do not understand and cannot explain everything, measurable or not. E.g. Einstein and quantum theory.
