Bypass Android Device LOD with Fiio E11
Jan 7, 2014 at 12:08 AM Thread Starter Post #1 of 3
BrainCity
Hi! I recently purchased a Fiio E11 paired with my ATH M50's and am very pleased with how it sounds. When I listen to music on my iPod Touch I use the Fiio L3, but when I use my Phone (LG Optimus G Pro) I have to use the phone's internal audio, diminishing the sound. Is there any work around so that I could bypass the line out? Any input would be great. Thanks
P.S. First post here, sorry if I'm a n00b :wink:
Jan 7, 2014 at 10:40 PM Post #2 of 3
Technically LG Optimus G Pro doesn't have 'line-out', but a headphone-out, and that's what you want to bypass. Never use one so I can't be 100% sure if it will work on the LG, but what you are looking for is an Android compatible USB DAC. Just search the forum for 'Android' and 'DAC' in the forum and you should fine plenty of option. The only question is which of them will work for your LG, and that's a question only a LG owner can tell you.
Jan 7, 2014 at 10:45 PM Post #3 of 3
Haha, that is what I feared. Having already purchased an amp, I don't foresee myself buying a DAC with it as well. Thanks for the response though, I appreciate the clarification.
