hardstyler
- Apr 29, 2006
I just ordered 770pro 80ohm version and I need to decide what amp to buy. I don't have any experience with amps so I need your help. The amp would be used for 80% desktop 20% portable/travel use. My budget is no more than Xenos X1HA-EPC which is $240.
Can someone compare Xenos X1HA-EPC with Total Bithead? I also have a laptop with onboard sound so Total Bithead would be nice to have but if it sounds much worse than Xenos then I'd definitely get Xenos. So which one would you buy for 770pro and are there any other good amps in this price range preferably with a built in DAC? Thanks.
