F107plus5
- Mar 23, 2006
Hi Matt!
I started by driving a 13/16" socket through the material after they had been installed for a day or so, so they may have stretched a bit before I punched the holes.(I took the pads off the cans first!
) At any rate the holes weren't quite large enough to reveal all the "rows of holes" visable in the driver screen, so I ended up cutting them big enough that all the rows were then barely showing.
Yuck! My ears are so small that they were hitting the screen!
THAT'S when I took them off and put them on the other way!
Rich.
...actually; a hole about the size of the one already in the pads for mounting would probably work just fine!
Originally Posted by mattg3 Thanks 107,and is the hole you cut to go over the phone based on a quarter mod size hole or should i use something else to measure the hole? thanks again Matt |
Hi Matt!
Rich.
