Dondoh
- Dec 4, 2007
I am going to buy replacements for the foam on my marshmallows.
This is my first trip into replacement foams.
First, What do you guys recommend to replace the foams on Marshmallows?
Second, What size should I get? They seal pretty well with the stock foams, but I suspect I could go size larger for a better fit. Would that mean going to a large size foamy, or are the original tips small?
Gracias
Gracias
