OK this is a conglomerate of previous posts sorry if there's repetition.
I've got a Sparkos Aries running from a Chord Qutest (sorry just gloating) for my home office. It is insanely good. I have the Conductor 3X ref in my main system which has a remote.
No remote for the Aries, that's a deal breaker for me in lounge room for music and AV. NO problem on desk of my home office. Same with the Qutest, also neither have bluetooth.
I've got sparkos dual pro opamps to try in my conductor 3X reference. I already have the vivids and the classics. It might be tricky to fit the Sparko pros in but I've got 3 solutions in my head. I got them before xmas. I'll post what they are like and how I installed them. If you can wait you might decide to try the sparko pros. I know they are more expensive, $55 more for dual pros with the adaptor so $110 more for a pair of dual Pros, but why not get the best? (actually it's slightly cheaper than that when you buy the pair)
Pros are singles, but Andrew was even nice enough to solder the pros together with the PRO TO DIP ADAPTER to make duals as I don't have a fine soldering iron for that fine work.
I have the Burson Conductor 3X ref which is a dac/headamp, but the DAC makes it a different configuration however the amp is in the same family as the Soloist. I bought a pair of V6 classics as Burson advised me to change the 2 classics for my Conductor 3x ref I haven't tried yet. Burson advised me to only change the LP stage and leave the V6 vivids in the IV stage. Lachlan from passion from sound said the same. If you have 4 classics you could change them in the LP (low pass) stage and listen, then change the ones in the IV Stage (IV =current to voltage ) and listen. Then all 4. I'm not 100% sure that the soloist pairs would be designated LP and IV though as it is an amp, not a dac+amp. I'd email burson.
In the end I would say change 1 pair at a time, listen, then the other, then all 4. see what you like best.
Andrew Sparko and I discussed this when I ordered a pair of his Sparko Pro op amps. He has advised others to change both pairs but was happy for me to try 2 pairs of pros. And they are much larger and draw more current. I might not be able to fit 4 in. Lachlan raved about the standard sparko opamps so I'm keen to try the pros.
Andrew sparko says......
So the signal output from the DAC chip itself is differential in nature (like an XLR, it has a HOT and COLD, or... in phase, and out of phase) and it is a CURRENT output. So it puts out a CURRENT based signal (rather than a voltage signal)
The point is though, that the current signal must be converted back to a voltage based signal at some point. And That is what I to V converters do. (the "I" stands for current, and the "V" stands for voltage)
Since it is a differential signal, you need two op amps for the I to V conversion. One op amp does the "hot side" and the other does the "cold side" Just like an XLR signal would have.
Then.... These differential signals get subtracted from each other in a final stage (diff amp stage, where they also usually do the filtering) to convert the differential signal back to single ended.
So most DACs will have 2 op amps for I to V conversion, and a final stage for Diff amping / filtering. 3 op amps per channel, 6 op amps total in a stereo configuration. That sounds like what they are doing.
I would say that they all should be discrete. Its not like the I to V converters are more or less important than the diffamp / filter stage is.
The Burson discrete OPA's pull quite a bit of current themselves when compared to what ICs pull, so the current draw should be OK as they seem to confirm.
Now, all of that being said, some guys will play around with things and decide that some op amp sounds better in the I to V stages, and some OTHER op amps sounds better in the Diffamp / filter stage. All of that is user preference and subjective and up to the end user at the end of the day.
And that is what makes all of this fun, right? Ha.
I hope all of that makes sense. Maybe Lachlan decided some IC sounded better in the I to V stages, and discrete sounded better in the Diffamp / Filter stage.
But I haven't tried the DUAL DISCRETE OP AMP SS3602 and I have got a conductor. But the soloist and the conductor have very similar amp sections. So my findings for the Conductor should match the soloist except for fitting mechanics as the layout is different.
Other than fitting the Sparko pros there is one issue, current draw. Burson said:
120ma is very high, it will not work in many applications but our Conductor is designed for opamp rolling so there is enough headroom for such current draw.
So when discussing V6 classics also Burson advised me to only change the LP stage and leave the V6 vivids in the IV stage. Lachlan at passion for sound said the same thing in one of his youtube reviews I think it was the soloist, or it may have been the Sparko opamps review. But Andrew from Sparko strongly recommended changing all 4 to a customer. I emailed him about that and he said you need to work out what the opamp is doing and if say it is running the balanced XLR outputs and you don't use them, then no need to change, but if you do use XLR change it.
So I might end up changing all 4, but I'm only changing the LP stage for the moment.
OK pro's into the conductor 3X reference are a work in progress PRO TO DUAL DIP8 ADAPTER and PRO DISCRETE OP AMP SS2590. Pics below. Note the placement of op amps and space/ height are different for different burson products so the soloist might be different solution due to opamp placement and lid height/room.
I didn't have a fine soldering iron so Andrew soldered 2 of the Pros and the dip 8 adapter for me and I currently have two dual PROs. Andrew is great just ask and let him know you've spoken to me.
At the moment I'm looking for a mounting solution for the two duals for LP stage. Once I've solved that I'll think about the IP stage. I have been able to get it up and running but not with the lid on. I'm pretty sure I can fix that. It immediately sounded better which didn't surprise, the Sparko Aries is full of PRO DISCRETE OP AMP SS2590 and it's sublime. But I only had a quick listen and I now have a problem with the CX3 ref, I think it might have shorted when I changed headphones. So I'm testing the C3X ref, it will probably have to go back to Melbourne.
120 milliamp is high for a pair of duals, that goes up to 240 for 2 pairs. That's a lot higher than the Burson current draw V6 Duals are 14mA, 28 for a pair of duals, 56 for two pairs
For products that help replace OEM opamps regarding space I've found some options.
Burson have 35 mm extension leads. If you are careful and bend them slowly you can bend them without breaking the wire. They have other stuff too.
https://www.bursonaudio.com/product/35mm-extension-lead-x-2/
These are longer, 40mm? and look more flexible
https://www.pornfreen.top/index.php?main_page=product_info&products_id=218375
This site is good and the short ones than come pre bent:
https://www.aliexpress.com/item/1005001345216954.html?spm=a2g0o.detail.1000014.1.1ecb48b85X3XFs&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.197020.0&scm_id=1007.14976.197020.0&scm-url=1007.14976.197020.0&pvid=067666d7-6398-4268-8c27-ea20cc9e9309&_t=gps-idcDetailBottomMoreOtherSeller,scm-url:1007.14976.197020.0,pvid:067666d7-6398-4268-8c27-ea20cc9e9309,tpp_buckets:668#0#131923#0_668#888#3325#2_4976#0#197020#11_4976#2711#7538#278_4976#3104#9653#10_4976#4052#21623#67_4976#3141#9887#2_668#2846#8113#1998_668#2717#7564#650_668#1000022185#1000066059#0_668#3422#15392#933_4452#0#189847#0_4452#3474#15675#128_4452#4862#22449#76_4452#3098#9599#90_4452#3564#16062#402
These will be part of my final solution I expect:
Also recommended by Andrew Sparko. He said: "
Digikey is a place like mouser. They just sell electronic parts and they sell pretty much everything."
Here's my work in progress:
Sparko pros as you can see the pin 1 orientation is pretty obvious:
Sparko pros, Burson V6 Classics, burson Dip 8 sockets mini extenders, burson 35 mm dip 8 extenders bent and unbent (be careful):
Conductor opamp configuration:
This shows how tight it is:
Lid off solution with Burson 35mm adaptors bent:
Can't run it with the lid on yet.
Some are more fanatical than me
Cheers
Sam
