Thanks for sharing your experience. It makes me more excited to receive mine. Hope you continue to do so as you have more time with the device.Just got the 3gt, did some testing between 3x in headphone amp mode and preamp mode.
I will include some comparison with ferrum oor and gsx mini based on my memory.
I am not the type that do long term comparison , quick ab on the same track at certain selected time point is the method. I believe if you can't hear the difference immediately, it's not there or at least not worth noticing.
PS 1. I use audio quest night owl and adx 5000 bal
2.The 5a supercharger psu is exactly the same shape and size of the 3a one but about 20% heavier
3.You can't hear the fan at all. It's definitely quieter than my room.
4. there is dc offset on start up and shut down of the 3gt. If you are like me connect a pair of active monitor to the 3gt, you gonna hear loud pop on you speak same as 3x.
5.the volume knob is still terrible, very easy to misbehave the way you want it to be.
6.the interface design is unthoughtful. They dedicated one buttons to rotate the screen, which is barely used for any one. If the use this button for crossfeed or just the select button instead of pressing the knob , it would make much more sense..
Ok here is the conclusion , 3gt is transparent, more so than gsx mini, ferrum oor , 3x
About the same level of tt2 but not hugo2 yet. Noise level is significantly lower than 3x and gsx mini on high gain.
Soundstage is very good, with the best depth perception among others. Dynamics is on par with gsx mini
Resolution is very good, detailed and controlled. On the same level of ferrum oor.
Imagining is top tier, better than the others.very vivid and holographic. Corssfeed is done well, you trade a bit of transparency for much better frontal depth. I think it's the best implementation of such feature I be heard so far. Better than Hugo and ifi stuff.
However those improvement is much more obvious in headphone amp mode than preamp mode.
sound wise 3gt is definitely a total headphone amp, however the interface design is flawed. Makes it less ideal and compelling as a top tier product.the dc offset problem is not only annoying but also dangerous for you other equipment, I wish burson would find a way to fix it.
I will keep updating if anything new came up. I am way pass the hype for new gear period of my life.but I am still thrilled for a while with 3gt.
Thank you for reading this gibberish, if you got any questions I will answer to the best of my knowledge.
Were you able to compare stock PSU vs Supercharger? I’m quite curious how much audible difference the SC makes on an already excellent sounding amp.
Too bad for the interface design. I probably won’t mind it after a while. If using the remote control instead, will the navigation improve significantly?
For dc offset, Does it mean it would be better to make sure headphones are unplugged before switching the amp on? I’m not familiar with dc offset in general, and what to watch out for.
