I’ve been running the SS2250s in the volume control, SS3306s in the input buffer, and the Muzg in the voltage gain with pleasing results (good balance of warmth, stage depth, bass slam, and details).
I finally got some more extensions and was able to try some new combinations.
I initially tried the following:
Input: SS2250
Volume: SS3306
Voltage: Muzg
The tonality became much more neutral with a treble emphasis that quite frankly made the music sibilant to my ears. Stage depth seemed wider but less accurate (for example, audience noise from live music felt pushed back but less holographic…like the sound was coming from one distance but far away). This config had good attack and fast transients at the cost of musicality (it felt less engaging because the sounds were less connected). Bass slam was also deceased. While not terrible, I did not like this config.
I then switched to the following:
Input: SS3306
Volume: Muzg
Voltage: SS22509
Ironically, this is the config I tried to do but the Burson extensions are too short and made it difficult to get a proper connection in my amp, especially with the 2023’s silent power modules taking up a bunch of space. What you see in the picture are with AliEx-purchased extensions, which are much longer than the Burson.
This configuration is much more intimate with a boost in miss. The stage feeling is little narrower but more detailed with better imaging. Highs are rolled off nicely (better than the original config stated above), especially when female vocals get loud.
Compared to the one I’ve been running (first one stated above), bass sounds about equal: good slam and extension. Similarly, I think it has good balance across the board with my chain. Where it surpasses the original config is in mid details, something my HEKse needs help with. It’s very subtle to my ears but I think I like this config the best so far. I could see myself swapping between this config and the original where the Muzg and SS2250 switch places.
